Creating a B16A Axle For a CRX
Old Jun 20, 2005 | 10:15 PM
Illtal's Avatar
Default Creating a B16A Axle For a CRX
Can any of you tell me the combination of axle parts I need to make a a set of b16a axles for a crx
I'm not too sure, but I think it's 90-93 integra inner slines and crx outers . . .
someone please confirm
Old Jun 20, 2005 | 10:18 PM
Ch3mik's Avatar
Default Re: Creating a B16A Axle For a CRX (Illtal)
umm. you use 91 integra axles. thats what ive used on 3 different b series motors
Old Jun 20, 2005 | 10:33 PM
solareclipseauto's Avatar
Default Re: Creating a B16A Axle For a CRX (Ch3mik)
i dont know what your tryin to create...just you 90-93 integra axles
Old Jun 20, 2005 | 11:04 PM
Illtal's Avatar
Default Re: Creating a B16A Axle For a CRX (solareclipseauto)
Thanx I didn't know that they fit through the hubs or not PEACE
Old Jun 21, 2005 | 12:41 AM
they fit as long as you have a 5 speed hub
Old Jun 21, 2005 | 08:14 AM
bagpipe goatee's Avatar
wow.
crx hf's have 5 speeds, and you need the knuckles off a dx/si to make it work. basicaly you need dx/lx/si knuckles with the hubs for it to work. if you have ex ones, good for you, you have really rare knuckles with bigger brakes, too.
with these axles, the joint is slightly bigger, so you have to pull off the metal dust ring on the inside of each hub so that it doesn't rub.
Old Jun 21, 2005 | 08:32 AM
aeonsi's Avatar
Default Re: (bagpipe goatee)
watch out for what center shaft you have. I can't find the resource right now but this is how it goes I believe:
90-91 jdm b16a teg, S1 and J1 tranny intermidiate shaft use 90-91 teg axles.
SiR jdm B16a intermidiate shaft (slightly longer than teg), PASS side use 90-91 teg, Drive side use 88-89 teg with 90-91 inner CV.
just get both 90-91 axles. if the drivers side is too long, your hub wont go back on the lower arm, go and get a 88-89 axle and hybrid the two you got for the D-side.
and you need to remove the metal shield on the hub/wheel bearing. (see pic)
someone please conferm or correct...
Old Jun 21, 2005 | 09:40 AM
rioninja's Avatar
Default Re: (aeonsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeonsi &raquo;</TD></TR><TR><TD CLASS="quote">watch out for what center shaft you have. I can't find the resource right now but this is how it goes I believe:
SiR jdm B16a intermidiate shaft (slightly longer than teg), PASS side use 90-91 teg, Drive side use 88-89 teg with 90-91 inner CV.</TD></TR></TABLE>
Thats correct, EXCEPT, you can just use the 86-89 axle on the drivers side without any modifying. It will fit perfectly with the longer (y1) intermediate shaft. Hub rings must be removed as usual.
Old Jun 21, 2005 | 10:45 AM
JOGADOGGZ's Avatar
Default Re: (rioninja)
This is the same application on a B16a EF with an s1 tranny, 90-91 passenger side axle from a teg and 86-89 drivier side teg. I'm swapping out my axles and i've forgotten which ones i needed.
Old Jun 21, 2005 | 12:01 PM
tgreaves's Avatar
Default Re: (JOGADOGGZ)
I cant remember what mid-shaft I have but I use both 90-91 ls integra non-abs axles with a jdm ys1 92-93 cable trans..
Old Jul 4, 2005 | 10:30 AM
Ch3mik's Avatar
Default Re: (tgreaves)
mid shaft? is it the same as the halfshaft? you use the 90-91 integra one of course. i think i posted already that YOU USE 90-91 AXLES & HALFSHAFT! lol
Old Jul 5, 2005 | 06:54 AM
rioninja's Avatar
Default Re: (Ch3mik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">mid shaft? is it the same as the halfshaft? you use the 90-91 integra one of course. i think i posted already that YOU USE 90-91 AXLES & HALFSHAFT! lol</TD></TR></TABLE>
When given a choice, yes. But a lot of people get the "y1" intermediate shaft with their swaps. In that case the 86-89 teg axle is a good substitute for the drivers side.
Old Jul 5, 2005 | 10:46 AM
DohcVtecCrx's Avatar
LOL I have done a ton of b-series swaps and always used the teg axles, with a y1 s1 j1 ys1 ect.
JDM_Si_EG6_FTW
Jun 1, 2010 12:10 PM
Crackback
Aug 3, 2008 12:01 PM
EF8-SiR
Dec 19, 2005 05:04 PM
I3ackfire
Mar 17, 2004 01:52 PM
pikappaphi
Oct 14, 2003 08:37 PM
