" COME AND GIVE ME YOUR OPION..... "
THIS IS THE FOLLOWING ITEMS I HAVE THATS ON MY D16A6 THAT JUST ON A MOTOR STAND. JUST GIVE ME YOUR OPION THANKS!!!
OBX 12:1 FMU
1ST GEN DSM INJECTORS 450cc
WALBRO FUEL PUMP
JG 4040 CAMSHAFT
SKUNK2 CAM GEAR
PORT & POLISH D16A6 HEAD WITH 3 ANGLE VALVE JOB
AND MATCHING THROTTLE-BODY
DUAL VALVE SPRING
ZC RODS WITH "98 D16Y8 PISTONS
PM7 ECU CHIPPED W/ 3 SEPERATE EPROMs
ZC TRANNY
NIPPON MLS HEAD GASKET
CENTERFORCE STAGE-1 CLUTCH
FIDANZA Flywheel
OBX PULLEYS (NO AC NOR PS)
HF UPPER HEADER W/ MACHINE MATCH RBH5 TURBO/HF ADAPTOR
RBH5 TURBO "PORT & POLISH, REBUILT"
AND FINALLY MY AUTOMATED RADIATOR
FOR BOTH MY ENGINE OIL AND COOLANT
TOOK A YEAR, BUT I'M ALMOST DONE.
THANKS,
thanks guys, will get rid of the FMU.
as for the ecu a friend of mine wrote 3 seperate bin files. i'm not limiting myself to 1 eprom, just incase one of the three was writin better then the two. all three eproms are socket on a seperate bread board (machine copper pcb boards w/ dip switches)
Modified by CRX-Sit`urbocharge at 11:31 AM 6/21/2005
OBX 12:1 FMU
WALBRO FUEL PUMP
JG 4040 CAMSHAFT
SKUNK2 CAM GEAR
DUAL VALVE SPRING
ZC TRANNY
FIDANZA Flywheel
THANKS,
1. Thats great and all, but why are you using an FMU when you have an ecu thats chipped?
2. I am not sure why you put Y8 pistons into an A6 block. It increases the compression ratio, which is bad for tuning and it increases the chances of detonation a lot.
Thats it, I love the head work though!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">2. I am not sure why you put Y8 pistons into an A6 block. It increases the compression ratio, which is bad for tuning and it increases the chances of detonation a lot.</TD></TR></TABLE>
I could be wrong but aren't the y8 pistons more dished then the a6 pistons, which actually means lower compression?
1) Throw that FMU in the garbage can!
2) Get a real maniflold
3) If your spending the money on headwork, why limit yourself with stock bottom end components?
4) How the hell do you chip an ECU with 3 diffrent EPROMS???
5) Put a turbo on the setup that will be able to keep up with the motor, ie. T3 or T3/T4 hybrid (if spool is a concern, know that I just tuned a CRX with a 14B that didn't make full boost until 4000rpm with a similar setup, and I make full boost at the same RPM using a 60 trim T3 with an extremely shitty .84 exhaust side, not to mention way more power).
If your interested I have internals and a turbo kit for sale...
LvN
Jun 12, 2008 01:13 PM
