Is there a ignition relay
Old Jun 20, 2005 | 07:16 PM
gutted-dx's Avatar
Default Is there a ignition relay *CAN SOMEONE TAKE A PICTURE*
If there is a ignition relay, where is it .
Thanks
Modified by gutted-dx at 4:01 PM 6/21/2005
Old Jun 20, 2005 | 08:03 PM
Skinflute22's Avatar
there is a starter relay and an ignition switch.. the starter relay is on the driver side under the dash on the side its a little black box that has a black/red black/blue/ white white wires goin to it i think and the ignition switch is in the steering colum
Old Jun 20, 2005 | 08:29 PM
gutted-dx's Avatar
Alright thanks i'll look for it
Old Jun 20, 2005 | 08:48 PM
Kwicko's Avatar
Default Re: (gutted-dx)
What's the car doing/not doing? What year, model, etc., is it?
Mike
Old Jun 20, 2005 | 09:04 PM
gutted-dx's Avatar
Not getting any power to ecu, or fuel pump, car just quit on me when i was driving
Old Jun 20, 2005 | 09:10 PM
DieMaster's Avatar
Needs to be About 20% Cooler
check your battery connections and all fuses under dash and under hood.
Old Jun 20, 2005 | 09:14 PM
gutted-dx's Avatar
Already have
Old Jun 20, 2005 | 09:42 PM
Mach69's Avatar
Is your main relay good? Any codes?
Old Jun 21, 2005 | 12:15 AM
NikoZai's Avatar
Default Re: (Mach69)
is your battery good... more important LOL
Old Jun 21, 2005 | 03:30 AM
Mr_Si-R's Avatar
main relay, that **** happen to me
Old Jun 21, 2005 | 04:06 AM
crx_88_si's Avatar
hit me up w/ an email mike@homemadeturbo.com and I'll send you an adobe PDF file that has instructions how to change it.
Old Jun 21, 2005 | 07:13 AM
gutted-dx's Avatar
The main relay is good and the battery is good also i was driving and then all the sudden my car died and i'm getting no power to the ecu or the fuel pump
Old Jun 21, 2005 | 07:28 AM
crx_88_si's Avatar
ignition switch?
Old Jun 21, 2005 | 07:58 AM
gutted-dx's Avatar
How do you replace the ignition switch, i tryed taking one off another car last night and couldn't cause some special bolts
Old Jun 21, 2005 | 08:25 AM
bagpipe goatee's Avatar
theres two screws in the back for the electronics, and to pull the cylinder out, you loosen the set screw around the rim, put the key in, turn it to I and then push in on the little catch around the rim and it should just pull right out.
it's probably the electronic side, though. i did a writeup on how to change/rebuild the ignition electronics, search archives for my name.
however, realize that rebuilding them does not ALWAYS work, because if the points are too worn down, it still won't connect.
Old Jun 21, 2005 | 09:09 AM
gutted-dx's Avatar
I'll give it a try, is there anyway to reuse the old key
Old Jun 21, 2005 | 03:01 PM
gutted-dx's Avatar
Bump for some pics, couldn't find the relay
Old Jun 21, 2005 | 03:04 PM
1SlowB16EF's Avatar
the relay is kind of behind the hood release... check your ignition switch had mine go bad ... take the switch off with the 2 small screws and see if the soldered joints look ok.. or once you find the relay you can jump it to see if it has power when its jumper
Old Jun 21, 2005 | 03:34 PM
gutted-dx's Avatar
Couldn't find the relay so i changed the switch, alright thanks i'll look for it
Goobergobbler
27
Jan 15, 2016 06:25 PM
D7KWagon
Aug 28, 2014 12:20 PM
carnot
Jul 9, 2012 05:28 AM
thegatekeeper14
Apr 21, 2008 02:29 PM
sxecustoms
Jun 11, 2003 07:47 PM
