soudn in trannny?
Old Jun 20, 2005 | 07:06 PM
FlsFinest
Guest
Posts: n/a
Default soudn in trannny?
while ideling i noticed a rattling noise in the tranny...soudns like either a peice of clutch or gear getting thrown around in the trannny? what would it be i know i need new bushings for the linkage it couldnt be that could it? and its a JDM ITR tranny, only sumtimes tho it happens....like if i rev it high like 5/6k and let it go after its slowd down around to idle you will hear something hitting the case of the trannny form the inside all the syrnos are fine it doesnt pop out of gear in any of them, so im guesing its a part of the clutch....i could always drop the tranny out and open up the case and take it out but i dont feel like doing that right now! what do you guys think it could be?
nothing serious if it drives fine rite?
Old Jun 20, 2005 | 08:14 PM
.RJ's Avatar
.RJ
Default Re: soudn in trannny? (FlsFinest)
clutch release bearing -or- input shaft bearing
Old Jun 20, 2005 | 10:19 PM
Bbasso's Avatar
Coooould be one of the spring on the clutch, if you have a sprung hub clutch.
Old Jun 21, 2005 | 12:14 PM
FlsFinest
Guest
Posts: n/a
i think its the pilot bearing or release bearing.... not sure might even be the diaphram springs on the clutch but eith way im good im going to buy a clutchmaster clutch kit clutch/pressure palte/throw out / pilot
Old Jun 21, 2005 | 01:52 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: (FlsFinest)
Are you sure its coming from the trans?
Old Jun 21, 2005 | 06:20 PM
Ill's Avatar
Ill
Likely the clutch spring or spring keeper in the disc. Search, this has been covered in the last week several times. Does it go away occaisionally? How many miles? Dragged / hard clutch use? (hard release at WOT / redline?)
Old Jun 21, 2005 | 08:49 PM
FlsFinest
Guest
Posts: n/a
no i got it, its the bushing for the shift linkage...shift smoother then helll now ater 1st gear im always in vtec never out :-)
Dobird78
Oct 10, 2013 06:25 PM
95BG33PGSR
Jul 19, 2011 03:22 AM
Ditdogs
Apr 17, 2004 10:57 PM
doublejz
Mar 9, 2004 01:19 PM
