EF Z10 Radius Arms question
Old Feb 12, 2002 | 06:43 AM
91SiKen's Avatar
Default EF Z10 Radius Arms question
Need to know if the Z10 EF kit allows for caster adjustment as the 92+ kit does. Found out yesterday on the allignment rack that a downhill, ice and snow assisted curbcheck at 5 mph may have caused enough tweakage to impact my caster on the side that got hit If I can have the added stiffness, and the ability to correct my caster, I will really have to find it in my budget to get the kit and quick (once the motorswap and bushings are done )
Old Feb 13, 2002 | 05:41 AM
91SiKen's Avatar
Default Re: EF Z10 Radius Arms question (91SiKen)
Any help? I have seen now that they will can affect caster, could I get 1.5 degrees out of them though? Or should I see a alignment shop with a frame rack?
Old Feb 14, 2002 | 01:12 AM
JDM_DOHC_SiR's Avatar
New User
Should I see a alignment shop with a frame rack?
Yes you should Just to make sure that everthing is straight
slow ef hatch
Suspension & Brakes
Jul 3, 2010 06:10 PM
raymas8
Aug 3, 2005 06:45 PM
