question about axles
Old Jun 20, 2005 | 05:24 PM
accordmandan's Avatar
Default question about axles
hey guys, i just wanted to ask if the axles that would be used for an LSD tranny from a type S h22a engine are the same as the axles from a regular hydraulic tranny from an h22a.
Old Jun 20, 2005 | 09:22 PM
K-Spec's Avatar
Default Re: question about axles (accordmandan)
Type S has ATTS where as the normal tranny may have LSD or not...however, they are both hydraulic trannies...so to answer your question...no, the ATTS and the non/LSD tranny do not have the same axles...the ATTS axles will be shorter because of the ATTS...different size driveshafts too (halfshaft).
Old Jun 21, 2005 | 12:12 AM
SKDRCR's Avatar
What's the tranny code?
Old Jun 21, 2005 | 02:45 PM
Default Re: question about axles (khalal538)
thanks
Old Jun 21, 2005 | 02:47 PM
Default Re: (SKDRCR)
m2b4
Old Jun 21, 2005 | 03:52 PM
veganej's Avatar
Default Re: (accordmandan)
you can use the stock axles from a lude w/ m2b4. that is not from a type s. its from a sir-s spec motor from what i hear. i have the same setup. i just used my axles and half shaft and everything is good.
Old Jun 21, 2005 | 10:16 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordmandan &raquo;</TD></TR><TR><TD CLASS="quote">m2b4</TD></TR></TABLE>
That's what I thought you actually meant.
Yes the stock h23 axles and intermediate shaft work fine
Ldo
Sep 11, 2008 06:06 PM
gimmethat
Oct 23, 2005 02:03 PM
chackoperformance
Mar 21, 2004 11:16 PM
drewlee
Oct 2, 2003 07:48 PM
