need help with a rear brake disc conversion asap!!!!
Old Jun 20, 2005 | 02:51 PM
cliff666's Avatar
Default need help with a rear brake disc conversion asap!!!!
we swapped over a freinds rear brakes on a 91 ef to 91 integra rear brakes. we used the DA's trailing arms and the DA's upper rear control arms but after we sat it on the ground the rear is higher than b4. the car sits on neuspeed greens and the offset completely out of whack now. my question is( i did do a search found nothing) should i have used the stock EF's rear upper control arms? instead of the DA ones?
any help will be appreciated
thanks
-cliff
Old Jun 20, 2005 | 03:03 PM
EL Vap133's Avatar
Default Re: need help with a rear brake disc conversion asap!!!! (bruceHungLO)
Yes, use the crx upper arms.
Old Jun 20, 2005 | 03:08 PM
DPSJosh's Avatar
Use the integra trailing arms and the ef's upper control arms.
classdork987654
Apr 1, 2009 02:56 PM
Ermil
23
Sep 29, 2008 09:42 AM
JDMThoughts
Mar 21, 2005 03:41 PM
h22dc2
Aug 17, 2002 07:14 PM
