high O2 sensor output voltage-bad measurement?
Is it possible to get an O2 sensor votage of over 1 volt?
I get a reading of 1.7 at wot sometimes, and sometimes .15-.25, but usually its at .4. If i keep a constant rev around 3k rpm, its around .35. If the o2 sensor is bad, wouldnt my ECU throw a code, or is it possible my O2 sensor reader is off/mis calibrated?
I'm running a greddy SOHC kit with the blue box.
I'm going to take the kit off next week or the week after to get a smog test, im afraid the o2 sensor is bad and will make my car fail.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by duh blacksheep »</TD></TR><TR><TD CLASS="quote">Is it possible to get an O2 sensor votage of over 1 volt?
I've seen a couple that had an internal short to the heater element make them go as high as 3 volts and not throw a code. Both were on 5th gen Civics. A properly working o2 sensor shouldn't go over 1 volt.
draxxus07
Oct 13, 2005 05:41 PM
duh blacksheep
Jun 21, 2005 06:05 PM
