obd1 conversion - resistor box w/'94 injectors?
Old Jun 20, 2005 | 12:51 PM
HiProfile's Avatar
Default obd1 conversion - resistor box w/'94 injectors?
I'm most of the way through my d16z6 swap into my '90 lx, and I'm wondering about this. The mpfi conversions are almost always for d16a6's & thier injectors and/or use the obd0 ecu.
I'm planning on using the stock z6 injectors (lx had 2 ) and a p28 ecu, so do I really need a resistor box? What about when I switch to dsm 450's when I put the turbo kit on? BTW searching either brings up hundreds of results (can't really refine the search), or just results that deal with the using obd0 ecu's/injectors. Thanks.
Old Jun 20, 2005 | 01:39 PM
dr_latino999's Avatar
Default Re: obd1 conversion - resistor box w/'94 injectors? (HiProfile)
OBD-1 Injectors require no resistor box. DSM injectors sometimes do, sometimes don't, it depends if they are low impedence or not.
Old Jun 20, 2005 | 01:52 PM
Mach69's Avatar
Default Re: obd1 conversion - resistor box w/'94 injectors? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">OBD-1 Injectors require no resistor box. DSM injectors sometimes do, sometimes don't, it depends if they are low impedence or not.</TD></TR></TABLE>
Correct There are some posts in the FAQ thread on the top of this forum about how to install DSM 450s into our cars. Try going through that thread. I'm sure you will find it and it will tell you how to install those.
Old Jun 20, 2005 | 02:34 PM
HiProfile's Avatar
Default Re: obd1 conversion - resistor box w/'94 injectors? (Mach69)
After I posted I noticed the answer for obd1's in the newer v1.4 boomslang conversion harness guide, but when I posted, my wifi farted (was in garage across yard).
I previously looked up the topic a lot for ek's and eg's (was going to turbo an ek, then wanted to turbo my eg, then had to go on a budget), but I never really thought about it for ef's.
Lately I'm just tryin to be spoon-fed answers since I'm doing what most don't try - d16z6 obd1 swap in a '90 LX sedan, to be turbo'd before August. I love all-motor & hatchs, but I want to be different (as much as I can be with a honda). The biggest prob is the lack of info, I have to make lots of educated guesses.
pinecone
Apr 25, 2006 06:41 AM
killa rex
Jan 25, 2006 02:54 AM
drSquish
Jan 19, 2006 01:54 PM
e jay one
Aug 6, 2005 02:48 PM
peiku
Jul 25, 2005 11:01 AM
