Smoke, No Vtec, Low oil, and Coolant on the dip stick!!!!!!!!!!!!!!!
Old Jun 20, 2005 | 12:09 PM
MR. BAR's Avatar
Default Smoke, No Vtec, Low oil, and Coolant on the dip stick!!!!!!!!!!!!!!!
Okay so last night im driving my car and vtec isnt kickin till 8krpms, so i pop the hood and the oil is a little low, theres liquid(im pretty sure its coolant) on the dipstick along with the oil, and theres white smoke coming out at low rpm and black smoke coming out at WOT. From what i have gathered i believe it could either be a head gasket or rings/seals, what do you guys think? Ohh yea and the iddle is very erratic but sometimes stops abruptly and rests at 500rpm's, but thats been happening for a couple weeks before the other problems started?
Old Jun 20, 2005 | 12:35 PM
Combustion Contraption's Avatar
Headgasket.
Dont drive it. Pull the head off. Replace head gasket.
Old Jun 20, 2005 | 12:48 PM
PreStaged12s's Avatar
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Headgasket.
Dont drive it. Pull the head off. Replace head gasket. </TD></TR></TABLE>
Most definitely a headgasket, the white smoke at idle is coolant burning up in the combustion chamber.
Old Jun 20, 2005 | 01:00 PM
MR. BAR's Avatar
So i cant even drive it at all, not even being very gentle and staying at low speeds?
Old Jun 20, 2005 | 01:53 PM
97tegGS's Avatar
yes, not at all.
Old Jun 20, 2005 | 01:55 PM
philafelman's Avatar
Default Re: (510gsrhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 510gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">So i cant even drive it at all, not even being very gentle and staying at low speeds?</TD></TR></TABLE>
dont make it worse than it already is. are you overheating at all?
Old Jun 20, 2005 | 02:10 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (philafelman)
Honda cylinder heads are aluminum. You could warp it VERY easilly or crack it. Stop driving and replace.
Old Jun 20, 2005 | 08:44 PM
MR. BAR's Avatar
Ya actually i have been feeling like the engine is slightly overheating when i get on the gas, and the check engine light started going on.
Old Jun 20, 2005 | 09:05 PM
SleepnCiViC's Avatar
jus dont drive it AT ALL!
Old Jun 21, 2005 | 05:11 PM
N_A_is_best's Avatar
Default Re: (SleepnCiViC)
definite do NOT DRIVE it get the headgasket and youll be set
goodluck
Old Jun 21, 2005 | 05:19 PM
moto1320's Avatar
Default Re: (N_A_is_best)
if you are going to pull the head yourself get it checked for warpage before bolting it down on a new gasket. Warpage, or worse, happens very fast. I had a customer bring in a used Lude he had just bought with the early signs of a headgasket going. He took it home against my instructions and showed up the next day with not only a head, but a block warped outside of useable limits. The block actually warped more than the head. New engine....Aluminium warping due to heat aside, the hot coolant can act as a wet saw under pressure on that soft metal and actually remove material.
Old Jun 21, 2005 | 10:28 PM
MR. BAR's Avatar
So i did a compression test and it whent
cylinder 1 : 215 (oil on the plug)
cylinder 2 : 190 (little less oil on the plug)
cylinder 3 : 155 (no oil little carbon plug)
cylinder 4 : 140 (lots of fuel on the plug running rich as hell i assume)
so i am just goin to pull the head and hope its only rings or valve seals, and not warped cylinder walls or anything worse.
DRoylflush
11
Apr 10, 2011 02:11 PM
pkjie108
Oct 12, 2006 06:29 PM
EF9 JAMS!!!
Aug 7, 2006 05:18 PM
4dr*sleeper
15
Aug 1, 2005 02:08 PM
M15
25
Oct 6, 2004 10:05 AM
