15/16 master cylinder?
Old Jun 20, 2005 | 11:13 AM
Merlin8188's Avatar
Default 15/16 master cylinder?
Just want to know if a 15/16 master cylinder will work with the upgraded disc, 10.2 in, and drum brakes in the rear? for an ef hatch
Old Jun 20, 2005 | 11:22 AM
mahatma's Avatar
Default Re: 15/16 master cylinder? (Merlin8188)
If you have the stock booster the only 15/16" MC that'll work w/o bending brake lines is from the 90-91 Civic EX sedan
Old Jun 20, 2005 | 12:09 PM
dr_latino999's Avatar
Default Re: 15/16 master cylinder? (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">If you have the stock booster the only 15/16" MC that'll work w/o bending brake lines is from the 90-91 Civic EX sedan</TD></TR></TABLE> ANDDDDD the 87-89 Accord LX-I.
Old Jun 20, 2005 | 12:24 PM
mahatma's Avatar
Default Re: 15/16 master cylinder? (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote"> ANDDDDD the 87-89 Accord LX-I.</TD></TR></TABLE>
Good man, thank you!
Old Jun 20, 2005 | 12:55 PM
EL Vap133's Avatar
.....and 90-93 non-abs Integra.
Old Jun 20, 2005 | 02:28 PM
ZhaGg's Avatar
Default Re: 15/16 master cylinder? (EL Vap133)
I got mine from a '91 (i think it was '91...) prelude Si
Old Jun 20, 2005 | 05:24 PM
bagpipe goatee's Avatar
i hate to call el vap wrong, but i was sure that for the 90-93 non-abs integra you had to change the booster because the flange for the m/c was rotated 90 degrees?
Old Jun 20, 2005 | 06:06 PM
eda6's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">i hate to call el vap wrong, but i was sure that for the 90-93 non-abs integra you had to change the booster because the flange for the m/c was rotated 90 degrees?</TD></TR></TABLE>
yep. The DA mc requires a DA booster.
Old Jun 20, 2005 | 06:57 PM
EL Vap133's Avatar
What I meant to say is he can also use the 90-93 Teg MC/BB.
Old Jun 20, 2005 | 07:06 PM
StupidSlowRSX's Avatar
Default Re: (EL Vap133)
I'm using 95 Del Sol VTEC master cyl and booster
Old Jun 21, 2005 | 06:29 AM
Cory man's Avatar
90-91 Civic EX M/C with stock booster. A good combo for the EX knuckles and brakes imo.
Old Jun 21, 2005 | 08:13 AM
rioninja's Avatar
Default Re: 15/16 master cylinder? (Cory man)
Yep. What i run.
And whats up Cory?
Old Jun 21, 2005 | 08:20 AM
turboEFboy's Avatar
wrong again (not being nasty),
But I am running the 15/16 90-91 integra non-abs MC with the stock crx BB. It fits perfectly.
Old Jun 21, 2005 | 12:14 PM
Rob.'s Avatar
Default Re: (turboEFboy)
whats the benefot of using the 15/16 MC ? What is the 1991 crx si one ?
Old Jun 21, 2005 | 12:36 PM
HumanResource's Avatar
Default Re: (Rob.)
BRAKE PEDAL FEEL = Main difference
If you go Big Brake minus the Migger MC then you get a SWITCH like brake pedal it can lock up w/o much effort from the driver
If you go to a BIGGER MC like the 15/16 then you get more relaxed pedal feel-requiring more driver INPUT for the same lock up
Each person has their own preference
In an Emergency Situation I tend to stomp on the pedal
I'd hate to lock the brakes in an emergency situation
Old Jun 21, 2005 | 01:43 PM
Keith P's Avatar
Default Re: (HumanResource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HumanResource &raquo;</TD></TR><TR><TD CLASS="quote">BRAKE PEDAL FEEL = Main difference
I'd hate to lock the brakes in an emergency situation </TD></TR></TABLE>
Something about this statement doesn't settle well with me.. Are you sure?
mr 636
10
May 20, 2006 12:17 PM
dthug
May 20, 2006 04:42 AM
Gump
Nov 23, 2005 02:40 PM
SAVIOVEGA
Nov 9, 2005 03:02 PM
Andres-eh2
Jul 11, 2004 07:44 PM
