adjusting F.camber with ball joint slider
any one using the SPC unit? Looks very bulky on the top, I'm very concern that I'll have to make a hole in my shock tower...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">Just dont lower your car to far or it will hit you shock tower over large bumps.</TD></TR></TABLE>
I've never had that hapen. I sell/install SPC adjustable ball joints all the time and have never had one bottom out on a tire. I've put them on cars dumped 3.5 inches (00 ccord) w/ no probs.
with those, do I need 90-91 A-arm? or can I use the 89 ones? What's the mounting method of those to my old arms?
TIA
TIA
They make one #67125 for the 88-91 Civic the uses your A arm, if you swapped to a DA arm it would be # 67135.
On either one, just remove your old bj, and replace with the adjustable one. You need to be on an alignment machine to get a readout unless you are just going to set it completely out.
I'm just wondering if I can remove my old ball joint out of my '89 A-arm as I did not think they where exchangable.
The 88-89 Civic/CRX Upper-A arms have the ball joints welded into them. Your est bet is to go get some 90-91 Civic/CRX Upper A-arms from the junkyard and take the OEM joint out to replace with the SPC Ball joint.
Hope that helps.
-Jon
Hope that helps.
-Jon
Aphelion
Aug 3, 2005 10:01 AM
MyDragCar
Dec 2, 2004 09:58 PM
