d16y8 Cam install question
Old Jun 20, 2005 | 10:08 AM
EJ8tunerman's Avatar
Default d16y8 Cam install question
When i go to install my crower camshaft which I will be receiving this week, how can I take the Timing Belt off the cam gear in order to remove the cam? Basically I'm saying will i be able to reach the tensioner just by removing the upper tb cover, which is held by the Valvecover, or do I have to take the crankpulley and lower timing belt cover off?
Old Jun 21, 2005 | 08:16 AM
civic-4-ges's Avatar
Default Re: d16y8 Cam install question (cb7tunerman)
Loosen the bolt to cam gear, take it off
Tap cam gear off of cam with belt attached, zip tie belt/cam to keep them locked together
Provide tension on the belt while swapping cam (block of wood..anything)
Set new cam in, put cam gear back on with timing belt tensioned
Old Jun 21, 2005 | 11:39 AM
91integraLSVTEC's Avatar
Default Re: d16y8 Cam install question (civic-4-ges)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic-4-ges &raquo;</TD></TR><TR><TD CLASS="quote">Loosen the bolt to cam gear, take it off
Set new cam in, put cam gear back on with timing belt tensioned</TD></TR></TABLE>
have you done that before? how did you get the camgear on the new cam with all that tension on the belt?
Old Jun 21, 2005 | 02:36 PM
Default Re: d16y8 Cam install question (91integraLSVTEC)
Does not take much, all you do is use a little arm strength, and it goes right on
Done this many many times---on a SOHC!
Old Jun 21, 2005 | 04:35 PM
moto1320's Avatar
Unless it's a new belt and still really snug them you can usually slip the belt off of the cam gear. that's what i have always done.....
DMCCOY
12
Jan 9, 2009 08:39 PM
integlstrike1
Aug 13, 2006 07:45 AM
4DRmafia
Dec 22, 2005 08:45 PM
HamiltonRex
Nov 13, 2004 05:50 PM
KooK
Apr 8, 2002 04:24 PM
