hissing noise... fuel leak?
Old Jun 20, 2005 | 09:47 AM
r0ckingrrl's Avatar
Default hissing noise... fuel leak?
I'm not quite sure where to start with this, but i'm not sure this is normal. I have a 93 5spd. ex coupe, and whenever I push the gas to accellerate, I hear a kind of hissing noise. It gets louder the farther I push the gas pedal in... if i just lightly push it I don't hear it. It only does it while it's in gear though. Could this be a gas leak or something? I don't smell anything, but I can hear it. I'm not quite sure what to think. Is there somewhere i could easily look to see if it is in fact a gas leak? I took it in for required maintenance about a month ago and the mechanic didn't say anything about it... maybe he didn't notice it. I'm not sure what to think about this... any advice would be welcome...
Old Jun 20, 2005 | 09:58 AM
raceACCORDingly's Avatar
vaccuum leak?
if its a fuel leak do you see any fuel?
Old Jun 20, 2005 | 10:28 AM
Stoich EG2's Avatar
Default Re: (raceACCORDingly)
Do you have an air intake?
Old Jun 25, 2005 | 04:11 PM
r0ckingrrl's Avatar
Default Re: (Advan06)
I can't see any fuel on the ground or leakage anywhere under the hood... and I don't have an aftermarket intake. I didn't think of a vacuum leak, but that sounds like it could be. How could I check and see if that is the problem? Would a vacuum leak cause the car to not accellerate as quickly, and maybe have lower gas mileage as well? I've been noticing that, but of course that could be unrelated... I'm just not sure.
edit:
Also... sometimes the idle goes up and down while in neutral, like, it goes down to just barely before it could stall, then goes up to around 1000, and keeps fluctuating for a while. Could that also be related to a vacuum leak?
Old Jun 25, 2005 | 04:53 PM
P_Adams's Avatar
Default Re: (r0ckingrrl)
You made no mention of power loss at speed, but the symptoms you discribe could indicate a blocked/clogged catalytic converter.
The conditions caused are usually:
1) loss of power at higher rpm, getting worst as the condition continues
2) Hissing noises from a blown exhaust donut/gasket as exhaust gas pressures increase (as rpm's build) between the engine / converter
3) Deminishing gas milage as the engine works harder to develope power.
Vacume leaks (on the intake side (where else)) woud actually be maximized at idle and decrease as you opened the throttle. Just the opposite of what you discribe.
Modified by P_Adams at 5:48 AM 6/26/2005
lucid77
13
Feb 23, 2013 06:02 AM
Jmumblez2001
Aug 13, 2006 12:40 PM
tealjdmcrx
Sep 27, 2005 07:13 PM
HamiltonRex
11
Nov 2, 2004 11:44 AM
DumpedSi
Aug 14, 2003 01:30 PM
