rear hub?
Old Jun 20, 2005 | 09:08 AM
jdm*Stars's Avatar
Default rear hub?
noob qustion ...do i need a pully to get the rear hub and bearing off the spindle ? thaks alot...
Old Jun 20, 2005 | 09:18 AM
jdm*Stars's Avatar
Default Re: rear hub? (jdm*Stars)
i just need to change the bearing how do i get that out and can i put the new one in by hand?
Old Jun 20, 2005 | 09:30 AM
Tyson's Avatar
you can pull it out without anytihng more than a RUBBER mallet. however, sometimes the inner race is seized on the spindle, and it kinda takes some work to get it off.
Old Jun 20, 2005 | 09:57 AM
jc836's Avatar
Default Re: rear hub? (Tyson)
Generally-NO you cannot replace the bearing only. You will need the complete hub assembly. They are available from any Timken supplier. I use an industrial bearing house but there are others out there. The Timken unit is ready to bolt on.
Old Jun 20, 2005 | 10:01 AM
jdm*Stars's Avatar
how would i go about taking the hub off ? thanks alot for the help..
Old Jun 20, 2005 | 10:22 AM
Tyson's Avatar
pry off the hub nut cover. pull out the cotter pin. break loose the spindle nut. pull the hub off. replace.
the hub and bearing are integrated in the same part. i figured you knew that.
Old Jun 20, 2005 | 10:44 AM
jdm*Stars's Avatar
i have the nut off the spindle and the bearing is on the spindle with the hub ...should i knock it off with a mallet or does it need a pulley becuse i herd it was pressed on the spindle,could i take out the spindle and replace that too ?
Old Jun 20, 2005 | 10:48 AM
Tyson's Avatar
rubber mallet will do.
Old Jun 20, 2005 | 10:51 AM
jdm*Stars's Avatar
i have the nut off the spindle and the bearing is on the spindle with the hub ...should i knock it off with a mallet or does it need a pulley?
Old Jun 20, 2005 | 10:58 AM
Tyson's Avatar
the bearing is integrated with the hub. knock out the hub, everything but the inner race of the bearing will come out.
Old Jun 20, 2005 | 01:45 PM
jdm*Stars's Avatar
ok .. im just gonna replace the hole TA i have everything i need ..i have the drum brake off i just need to figure out how to get the E-brake cable out of the inside of the brake . any ideas ?
DmcL
Nov 8, 2006 09:15 AM
bward
Jul 17, 2006 07:40 AM
drftda
Jan 22, 2006 10:22 AM
shorti
10
Jan 14, 2003 12:22 PM
jasonb
Jun 22, 2002 07:17 AM
