Suspension & Brakes Theory, alignment, spring rates....
car sags to one side
Old Jun 20, 2005 | 08:22 AM
uniacke-hatch's Avatar
Default car sags to one side
My car sags to one side. I measures the didtance nfrom the center of the wheel to the fender and its smaller on the drivers side by a couple inches. My coils arent broken. But all of my suspension components are probably original. Car has 338,000kms on it. Would my coil just be old and worn out?
Old Jun 20, 2005 | 08:29 AM
solareclipseauto's Avatar
Default Re: car sags to one side (uniacke-hatch)
change your shocks
Old Jun 20, 2005 | 08:33 AM
be.twenty's Avatar
Default Re: car sags to one side (solareclipseauto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solareclipseauto &raquo;</TD></TR><TR><TD CLASS="quote">change your shocks</TD></TR></TABLE>
how do you figure shocks affect height?
Old Jun 20, 2005 | 09:36 AM
EK k kay's Avatar
Default Re: car sags to one side (99_dc)
My 99 hb does that. Never found out why, but I did find out that many other people with civics have the same problem. I've tried new springs, new struts, alignment. I remedied it with coilovers though.
Old Jun 20, 2005 | 09:58 AM
typerhedlights's Avatar
shocks dont cause a certain side of the car to sag. your springs do. proven fact
Old Jun 20, 2005 | 10:11 AM
DFW's Avatar
DFW
Default Re: (typerhedlights)
If it's not sagging by a lot then it's normal.
Old Jun 20, 2005 | 10:36 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uniacke-hatch &raquo;</TD></TR><TR><TD CLASS="quote">My car sags to one side. I measures the didtance nfrom the center of the wheel to the fender and its smaller on the drivers side by a couple inches. My coils arent broken. But all of my suspension components are probably original. Car has 338,000kms on it. Would my coil just be old and worn out?</TD></TR></TABLE>
If this car is a 96-00 civic, and the drivers side is lower, than this is completely normal. Honda even published a TSB about it, because so many people were going into the dealer thinking there was a problem with their cars.
Old Jun 20, 2005 | 10:53 AM
chusoblu's Avatar
Default Re: car sags to one side (AutoXer)
uneven weight distribution?
Old Jun 20, 2005 | 11:27 AM
AutoXer's Avatar
Default Re: car sags to one side (chusoblu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chusoblu &raquo;</TD></TR><TR><TD CLASS="quote">uneven weight distribution?</TD></TR></TABLE>
I'm guessing that's the cause. If you look into the engine bay, almost all of it's weight is on that side of the car. The tranny also has most of it's weight towards the centerline of the car, so it doesn't offset any of that weight.
Old Jun 20, 2005 | 02:15 PM
My car is a 95 hatchback. When I changes to a wider tire (195/50R15) the one side rubs when I hit a good size bump. And there is no avoiding bumps. I live in rural Nova Scotia. How long do coils last?
98savage
Apr 11, 2007 01:00 PM
hon da top
Mar 4, 2007 10:45 AM
EG2Driver
Suspension & Brakes
May 26, 2006 12:40 PM
LS_V-tec_tegra
Sep 21, 2005 10:14 AM
rota power
Suspension & Brakes
Aug 10, 2005 07:57 PM
