Went to the track.........not happy...
Well we finally got the car to the track and had some serious wheel spin issues in the top end. My 60's were great and getting it out of the hole was not a problem. It was when it hit full boost it was pulling side to side and just spinning and there was nothing that i could do about it.
Here's my best time:
60' 1.720
330 5.02
1/8 7.65 @ 91.6mph
1000 9.97
1/4 11.92 @ 106.7mph WTF!!!
The setup is:
604whp
26" x 8.5 x 15 MT ET Drags
Solid motor mounts
Shitty 2 year old tokico struts and tenzo coil overs
Open Diff
Car maybe weighs 2500 w/driver (estimate)
Also on stock axles still
The turbo is rather laggy but that helps out of the hole. The problem starts once it hits full boost. Then i tried everything in my power to get them to stop spinning but it was just pulling from side to side and spinning so hard the car just wouldn't move. I tried just staying in it for a pass and that was worse. lol I'm getting LSD before i even attempt to go back to the track. That's what i think the majority of the problem is.
Here's the only picture i got at the track because all 8 batteries for the camera were dead
. I also have some video of the car at the track, i'll try to get it up this week.
60' 1.720
330 5.02
1/8 7.65 @ 91.6mph
1000 9.97
The setup is:
604whp
Solid motor mounts
Open Diff
Wow 604HP on stock axles im surprised you didnt snap them. But other than that thats still a quick time for an accord. Sliding back and forth sounds like powers not distributing equally to both front wheels. Id say get an LSD as you said.
I made probably 8-10 passes at the track and i was cutting consistent 1.8 60' times and a couple 1.7 60's. Axles are still strong. I brought a back up set of oem's just in case
Damn 1.8 and 1.7 60 fts with no LSD is pretty good. Big slicks thrive off of LSD and the ability to get them warm, especially with a heavier chassis. Atleast you know how to improve, and those improvements are going to make a big difference. If this is the first time at the track with that set-up, you should be happy. You have the power, now you just have to make that sucka go down the strip some-what straight
. Good Luck.
. Good Luck.
thats a hella low trap speed for an 11 sec pass...so its ovbious your biggest problem is keeping everything hooked up once the snail hits full boost....new struts and better springs might help keep the car under control as well
what gear do the tires finally hook up without any wheel spin at all? also, just for ***** and giggles, you might try launching in 2nd just to see what happens...if it doesn't let the wheels spin until 25-30 mph, you might pick up some time there...but the lsd should help immensely with your traction problems...
OT
i still dont think you have stated how much money youve spent on your ride.. a couple of pple (including myself) have asked in the first thread you started introducing yourself and your car.
but its wild driving something thats spinning at 100 mph isnt it?
Guest
Posts: n/a
wow..so u built ur car to 600+ HP and this is ur first time taking it to the track? was it garaged up ebing worked on the whole time??..but yea, LSD and better suspension set-up will cure ur problem, or atleast help it...and just curious, wut kinda turbo set up u got and how much boost...and wut motor, i dunt think u stated it, or m,aybe i missed it...o yea, props on the ride too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mac_24_seven »</TD></TR><TR><TD CLASS="quote">OT
too much $$$ and i don't know i never kept track
on street tires at full power(604whp) it breaks the tires loose in 5th gear on the street. Doesn't matter how fast im' going.
</TD></TR></TABLE>too much $$$ and i don't know i never kept track
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag-Accord »</TD></TR><TR><TD CLASS="quote">
on street tires at full power(604whp) it breaks the tires loose in 5th gear on the street. Doesn't matter how fast im' going.</TD></TR></TABLE>
with open diff i would think so lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.Speed »</TD></TR><TR><TD CLASS="quote">Sorry for asking question but i search and could not find answer,
What is LSD?
Thx</TD></TR></TABLE>
lysergic acid diethylamide...its a drug dummy. geez..dont you know anything??? everyones telling him he needs to take drugs!!!!
(jk)
limited slip differential..distributes traction to both wheels instead of one.
What is LSD?
(jk)
Glad you made it to the track. I'd be super happy to have your time slip!
You can weigh your vehicle by going to a truck scale and if no one's there drive on it. Or you can get it cleared with the people working the truck scales.
I have a 95 Accord H22A at about 180WHP, NA no real power mods and the best on street tires open diff was 14.871 @ 94.45 Once I got my Quaife LSD installed I didn't get faster at the drag stip but wheels pulled both at the same time so I was heppy. And it really helped in Auto-x racing. Here's my numbers below to compare to yours:
60' 1.720 Bruce = 2.381
330 5.02, Bruce = 6.391
1/8 7.65 @ 91.6mph, Bruce = 9.674 @ 75.58
1000 9.97, Bruce = 12.58
1/4 11.92 @ 106.7mph, Bruce = 14.871 @ 94.45
Well best wishes getting your LSD and getting back out to the track. You should think about auto-x with your Accord
It would be fun for you I think and nice to see an Accord beat a few WRX's in the SM (Street Modified) class.
Bruce
It would be fun for you I think and nice to see an Accord beat a few WRX's in the SM (Street Modified) class.Bruce
install an LSD which will help with the torque steer from side to side... altho with hooking up traction wise.. just wondering what your tire pressure is with the MT's running that much power they should be extra low.. 7-8psi.. maybe even 5-6 psi if there still is a problem.. if that doesnt help.. you'll either need bigger slicks or a 2-step and turn it off for 3rd gear.. since im guessing 1st and 2nd are useless gears after full spool... just some suggestions that worked for us
i was running the 26" MT's at 7 psi. Having absolutely no problems getting the car out of the hole.
1st and 2nd gear are not problem because i don't get to full boost until the top of 2nd.
Quaife LSD is ordered and on it's way
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag-Accord »</TD></TR><TR><TD CLASS="quote">i was running the 26" MT's at 7 psi. Having absolutely no problems getting the car out of the hole.
yeah....add that to the "unaccounted" money already spent....lol
</TD></TR></TABLE>yeah....add that to the "unaccounted" money already spent....lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM MonopolyMan »</TD></TR><TR><TD CLASS="quote">how much was the quaife and when is the track open next to see your improved times?</TD></TR></TABLE>
$800 Brand new in box (found on ebay) and yes i already have a tracking number
Next track date is July 16th
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by as_fast_as_u »</TD></TR><TR><TD CLASS="quote">
yeah....add that to the "unaccounted" money already spent....lol </TD></TR></TABLE>
gotta admire a man and his ambitions....i just wanted to say for once, that I knew a guy with an ULTIMATE ******* ACCORD EVAR!!!!!!
keep up good work.....I think I speak for everyone: you make us accord owners proud!!!
Good luck!
Good luck!
