Can't take out slack on timing belt
Old Jun 20, 2005 | 05:25 AM
neumonik's Avatar
Default Can't take out slack on timing belt
I'm installing a timing belt on a b16a2 and I cannot for the life of me get the tensioner to pick up the slack. I've followed the directions in the helms.
Line the crank pully up at TDC.
Line the cam gears up at TDC via the center marks (closest each other).
With tensioner bolt tight go around the exhaust gear first then the intake
Losen and retighten the tensioner bolt
Turn the crank 5 - 6 times counter clockwise
set back to TDC and losen the tensioner bolt 180* (1/2 turn)
Rotate crank counter clockwise by three teeth on the cam gear
retighten the tensioner bolt.
All fine and dandy.... but even after I do all that there is still a ton of slack. So much in fact I can pull the belt off without even losen the tensioner.
What is the problem here??? Could the tensioner be shot?
Old Jun 20, 2005 | 09:03 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
it's either a worn timing belt, or a worn tensioner. it can't be anything else.
Old Jun 20, 2005 | 09:12 AM
PTR1's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
use a clothes hanger and pull up on the tensioner before you tighten it
Old Jun 20, 2005 | 12:49 PM
Suck my DX's Avatar
Default Re: (VIMPORT.COM)
did u change the tensioner pulley spring???when i swapped my cams i changed my tbelt at the same time...it wouldnt tighten for shiyyt....all i did was swap out the tensioner pulley spring and it tightened up no problem
Old Jun 20, 2005 | 02:43 PM
slomofo's Avatar
GDD Member
I get a screwdriver and push on the tensioner while someone else tightens the 14mm bolt that holds it down.
b00st Junkie
Jul 24, 2010 07:29 PM
neoc03
Jul 8, 2008 09:47 AM
god.loves.ugly
Jan 18, 2007 03:44 PM
thunteg
Aug 13, 2004 10:29 PM
Shady Hills
Jul 24, 2004 09:40 PM
