New Engine 96 prelude
Old Jun 19, 2005 | 09:46 PM
papaduhon's Avatar
Default New Engine 96 prelude
I have a 96 prelude h23 non-Vtec with 192,000 miles on it that i think is burning oil. instead of buying a new car and to avoid car payments, im going to put a new engine in it. I want to put turbo on the new engine. what is the best engine to do this with without spending ALL my money?
Old Jun 19, 2005 | 09:48 PM
ProjectDarkBlack's Avatar
Default Re: New Engine 96 prelude (papaduhon)
how much oil is it burning? you could probably pick up a junkyard replacement for less than $500 or buy one from a H-t member
Old Jun 20, 2005 | 09:39 AM
papaduhon's Avatar
Default Re: New Engine 96 prelude (ProjectDarkBlack)
Its burning enough to be irritating. I keep a bottle of oil in back seat. this is the situation.
i myself have little knowledge of a my prelude but my step father is a mechanic so im trying to buy a different engine for the car than an H23. i wanted a little more power and as mentioned above. good turbo compatibility.
Old Jun 20, 2005 | 12:23 PM
mgags7's Avatar
just rebuild the h23 and turbo it....if you changed to an h22 and then turbo you would spend all your money...
Old Jun 20, 2005 | 01:04 PM
GaRn's Avatar
Default Re: (mgags7)
If you want a good replacement go for a JDM F22b, 160 hp but iron sleeves I believe....
Old Jun 20, 2005 | 01:11 PM
Sam1am26's Avatar
Default Re: (GaRn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn &raquo;</TD></TR><TR><TD CLASS="quote">If you want a good replacement go for a JDM F22b, 160 hp but iron sleeves I believe....</TD></TR></TABLE>
Or just get any low mileage f-series block from a junkyard, slap your h23 head on it and boost away...
Old Jun 20, 2005 | 01:52 PM
h8trix's Avatar
I have a perfectly fine h23 engine if you want it. I swapped some bolt on parts from the h23 to my h22 I am putting in. The only problem is that the transmission (5spd) was giving me some issues. I looked into getting it repaired and the cost was too high and I wanted to get a VTEC anyway, just gave me an excuse
I am located in NJ if you are interested... I could probably arrange some transportation (if you are in VA, especially north-east VA) and wouldn't charge much for the engine.
Old Jun 20, 2005 | 07:04 PM
kickinchicken's Avatar
rebuild/replace and turbo...
hackblack
Mar 18, 2022 06:10 PM
mikegoree
Feb 13, 2008 08:15 AM
prelude964
Sep 29, 2005 05:31 PM
J_Lude07
Apr 27, 2005 09:07 AM
ArmyGuard18
Apr 20, 2003 04:14 PM
