Which Rocket Motorsports valvetrain to use
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the g2 teg »</TD></TR><TR><TD CLASS="quote">the valvetrain will come with the cams, along with spark plugs and a ECU chip</TD></TR></TABLE>
? What kind of answer was that.
Usually Rocket only sells the cams with these parts as a package, so if you have the cams you also should have got the corresponding valve train parts. If not, easiest solution would be to ask the man himself by dropping him an email.
I recommend that you use the GEN 2 SPRINGS/RETAINERS as they are best suited for naturally aspirated applications. GEN 1 SPRINGS/RETAINERS are for FORCED INDUCTION/HIGH BOOST/NITROUS applications. Hope this helps. Good luck.
Either will work.....the Gen 2 springs and retainers have held and are safe for just about any camshaft out there to handle 9,500. They have a lighter spring preasure than the Gen 1's, but if I'm not mistaken I think I saw Rocket say that he personally likes the Gen 1's, pretty sure he did a test comparing the two on a dyno. Where you at Rocket?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjo »</TD></TR><TR><TD CLASS="quote">You could ask Rocket.
lol i always wonder why people start threads when rocket is always more than willing to help, and not too hard to get in contact with.
</TD></TR></TABLE>lol i always wonder why people start threads when rocket is always more than willing to help, and not too hard to get in contact with.
I would reccomend the Gen2 springs and retainers as they have low seat pressure when compared to the gen 1 stuff. If your cams have large primaries then the GEN 1's are reccomended.
but selling springs based on motor application is wrong imo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kadburry »</TD></TR><TR><TD CLASS="quote">i asked rocket about this and he said he puts the gen1 springs/retainers in the m22 package</TD></TR></TABLE>
Correct!
Correct!
all-mtr-teg
10
Dec 25, 2006 08:43 PM
eg-ed
Aug 20, 2006 03:24 PM
Undercover_Skank
Nov 1, 2004 07:05 PM
