question about clutch slave
Old Jun 19, 2005 | 03:57 PM
itr514's Avatar
Default question about clutch slave
my clutch is sqeaking and the dealer told me its the slave for the clutch. I took a few pictures to go along with the question I have.
the slave:
my question is if the rubber piece covering the metal part should be connected to the where the metal piece goes in or can it be loose like mine is? It looks lubed up becuase I just sprayed it with white grease, but only helps the sqeak temporarily.
Is the grease drying up because it isn't covered?
Should I just replace the slave? If so, are there any good articles online? (I don't have much experience working on my car)
Any other suggestions would be great! I'm so sick and tired of that sqeak.
Sorry if this post is confusing!
Andrew
Old Jun 19, 2005 | 05:56 PM
Chiller's Avatar
the sqeak could be coming from a number of places. Did you try and lube between the slave cylider and the fork? There are a lot of posts on this try searching around some.
Old Jun 19, 2005 | 06:13 PM
.water's Avatar
Default Re: question about clutch slave (itr514)
https://honda-tech.com/zerothread?id=179021
eklum
Dec 29, 2006 11:04 PM
GSRwBOOST
Oct 23, 2006 11:41 AM
airikkCRX
Mar 24, 2006 04:29 PM
imported204
Oct 13, 2002 11:49 AM
