type r vs si master cylinder?
I just had all the brakes and suspension swapped from my type r to a civic do i need to change the master cylinder too. Just wandering if there is a diffrence in the two?
They are different. The Type R master cylinder is larger than the Si master cylinder. Both master cylinders work, but the Type R master cylinder is made for the larger Type R brakes, so I would recommend the Type R master cylinder.
MugenManR
Jun 8, 2007 05:08 PM
