b16 CEL problem
Old Jun 19, 2005 | 03:12 PM
CRseXy's Avatar
Default b16 CEL problem
Im looking at buying this b16 out of this CRX. and my Brother goes to look at it today. and it has a mis at 5k rpm. it is fine at idle. also, there a CEL, he looked at the ECU, and its a solid Red.
Any ideas? thanks guys.
Old Jun 19, 2005 | 03:29 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: b16 CEL problem (pogiTSI)
possible bad ecu, also check the ground on the thermostat housing, if its loose it will also cause a solid cell
Old Jun 19, 2005 | 04:14 PM
CRseXy's Avatar
Default Re: b16 CEL problem (PURPLETERROR)
hmm. ill check out that ground when I get a chance.
Old Jun 19, 2005 | 04:21 PM
CRseXy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">hmm. ill check out that ground when I get a chance. </TD></TR></TABLE>
Also, I was reading some searches about Soild ECU lights, and alot of them said that a soild ECU light means its ok. but they also said you have to jump wires to get the ECU to flash the code.
Its a pr3 ecu. OBD0. so there are no wires to jump right? its in a CRX also BTW.
doublethink's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR &raquo;</TD></TR><TR><TD CLASS="quote">possible bad ecu, also check the ground on the thermostat housing, if its loose it will also cause a solid cell</TD></TR></TABLE>
my ecu that lost injector pulse had a solid red CEL. in the helms it does say thats what it means [bad ecu]
but thats very good advice about the grounds. check them too!
Old Jun 19, 2005 | 04:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pogiTSI &raquo;</TD></TR><TR><TD CLASS="quote">Its a pr3 ecu. OBD0. so there are no wires to jump right? its in a CRX also BTW.</TD></TR></TABLE>
pre obd flashes without anything being jumped. if its not flashing something is very wrong.
when you first give power to an obd0 ecu it will quickly flash once, this is the Power On Self Test [POST]
after that it should flash and give you any codes it has, unless the problem is intermittent, in which case you lose the code., which is why pre obd can be a bitch sometimes.
Old Jun 19, 2005 | 04:41 PM
CRseXy's Avatar
Default Re: b16 CEL problem (doublethink)
ahh yah, thats what I thought, Then its probly a bad ECU then. ****. I have a p28 ecu that i would like to use. but that means I gotta convert to obd1. meaning, jumper harness. and Distrubutor.
curtis318b16
Jul 25, 2007 09:38 AM
b16nonoy
Feb 19, 2007 12:59 AM
stillrockin18s
Jun 27, 2005 09:38 AM
TurboRedSi
Jul 17, 2003 10:59 PM
riceball777
Jun 1, 2003 01:46 AM
