SI owners: How do i change my clutch fluid?
I SEARCHED!!!
now that we're done with that, how do i change the clutch fluid in my 00si? I looked at the clutch fluid and it looks like think syrup. I was hoping some of you guys had pictures of what to do.
TIA
TIA
Probably the same way as you change brake fluid.
Top off the master cylinder for the clutch, open the bleeder on the tranny/slave cylinder, pump the clutch to move fluid through, and keep the master cylinder topped off and keep pumping fluid through the line until you get clean fluid coming out. Close up the bleeder screw and call it a day.
bleeder screw is located by your radiator, its a black metal thingy with a hardline going to it. Go to a petstore and buy the clear fish air line hose helps so you dont make a mess.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Samurai »</TD></TR><TR><TD CLASS="quote">bleeder screw is located by your radiator, its a black metal thingy with a hardline going to it. Go to a petstore and buy the clear fish air line hose helps so you dont make a mess.</TD></TR></TABLE>
Also so you dont introduce air into the line. Because if you do you'll be making a new thread going "OMFG why is my clutch so mushy!?"
