proportioning valve theory
Old Jun 19, 2005 | 03:05 PM
GSRCRXsi's Avatar
Default proportioning valve theory
this is weird, i just looked at my prop valve on my crx and it says 2040. its a 91 crx si with 4 wheel disc stock. i thought they were 4040. so what does this mean? what actually changes when you change to a different prop valve? im thinking i might want to go with a 40/40 but im not sure. i want to fully understand this.
Old Jun 19, 2005 | 07:17 PM
StupidSlowRSX's Avatar
Default Re: proportioning valve theory (GSRCRXsi)
I got a 90 Si porp valve and its the same thing. 20/40
The DX one that I had on my car was like 17/35. Theres a noticable different. The rear tires lock up as oppose to the front. Which means when the car is under heavy breaking the weight is transfered to the wheels that aren't locking up. Thus, creating a better skidpad result.
Old Jun 19, 2005 | 08:12 PM
GSRCRXsi's Avatar
Default Re: proportioning valve theory (StupidSlowCRX)
i know what it does, but i want to know how it works. and if going to the 4040 would be worth it over the 2040
Old Jun 19, 2005 | 08:18 PM
RYANR1's Avatar
The 20/40 is refering to the predetermined pressure the proportioning valve stops fluid flow to the rear brakes.
Old Jun 19, 2005 | 08:27 PM
GSRCRXsi's Avatar
Default Re: proportioning valve theory (RYANR1)
so what will change when i switch to a 4040? how will the braking be different?
ys1civic
Feb 2, 2006 05:58 PM
GSRCRXsi
Jun 19, 2005 06:12 PM
ExodusJKD
Jul 11, 2004 06:56 AM
EL Vap133
47
Dec 19, 2003 08:27 AM
NINJASPY
Jun 3, 2003 12:02 PM
