where did this head come from?
I got this head for a stupidly cheap deal (400) from a guy who got out of the car thing so he pretty much gave it to me. The thing is I dont have a goddamn clue which b-series head it is
It does say pr3-3 on the front
here are some pics
Modified by electric-boost at 8:29 PM 6/30/2005
Modified by electric-boost at 1:00 PM 7/1/2005
It does say pr3-3 on the fronthere are some pics
Pr3-X is a b16 or ITR head. The last number is of no interest in the identification of the head. Just do a search, this subject has been covered like a million times before.
ok so here are the vec solenoid plug and oil pressure sensor plug from the unkown head. Now im not sure if they are the same regarless of what obd they are but I unplugged those wires and plugs from the unkown head and plugged the vtec oil pressure sensor plug and the vtec solenoid plug into my obd2 d16y8 head and they fit perfectly. But the thing is I dont know if ech gen has a different style of plug or there all the same (im betting they are the same) but I took a couple more pics of the head to help identify it but im not sure what to think of it.
It's a B16 head casting for sure... but being that it's a 2001 head... it might even be a ITR head. But don't get your hopes up, it's probably a b16. Check the valvesprings, if the top of the springs have blue AND yellow paint (for intake and exhaust respectively) then you might have yourself a ITR head.
but with cam gears too... it's a damn good deal. I would bring it to a machine shop, just to be safe (to get it checked out)
look in the intake ports. any sign of porting?
any color mark on the top dizzy bolt hole?
dual springs on both sides?
are the valves necked?
if no to the above, its probly a b16 head. if yes to all, its probly itr
If you want to know if its an ITR head, look down into one of the intake ports..Look down by the head of the valve, does it look like its was machined at all? Smoother then the rest of the port itself.. When they do the mild port job on the head its ony the area just around the opening of the valve, so if it looks nive and smooth like a cut finish by a cutting tool/grinder then its an itr.. My Itr head is a 0/0 just like yours in the pic..
either way the head is junk and no use to you.. I'll give you 200 for it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxrpm »</TD></TR><TR><TD CLASS="quote">A pr3 is b16 head. the 3 means its a sir III.
I had a b16 engine and the head was stamped with pr3-2, which is from a jdm 92 b16 sir II. </TD></TR></TABLE>
you sir, are wrong. My ITR head is also a PR3-3 head. As said before the last digit is irrelevant to identifying the head, it's more like a casting #. But the ITR should have dual exhaust springs, glob of green paint in the area behind the distributor mount, and also some porting in the bowl area.Also the date stamps will help you by telling when it was cast. But all this info is available right here in the Honda-Tech archives if any of you lazy *** guys would have bothered to do a SEARCH!!!
My ITR head is stamped PR3-3, my B17 head is stamped PR3-3, so to whoever stated that it's an SIR-III motor,; YOU sir, are an idiot!
To electric-boost - Why don't you take off all the 12mm bolts on top of the head, remove the cam caps/oil squirters, then check the rings on the cams to identify which cams they are, then while the cams are out, check to see if the exhaust valve springs have little tiny springs inside of them.
PR3 = B16 head
And according to the stamp, it was the 9th head made on 9-20-00. This means it came off of a 2001 Civic Si most likely!
ITR heads should be stamped P73.
Very Emergency!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid_vtec »</TD></TR><TR><TD CLASS="quote">PR3 = B16 head
ITR heads should be stamped P73.</TD></TR></TABLE>
first there were no 01 civic si. the last b16 in america was in 00. and 9 of 2000 would make it an 01 head and the only pr3 head sold in america in 2001 was an itr one. this kid might have lucked out.
it only says p73 on the timing covers and ecu......not on the head.
