1990 accord automatic motor mount problem
I just replaced the front and rear mounts on a 1990 accord automatic. When the car is stopped and you shift from park to reverse or to drive the motor moves a lot. I dont know much about the vacuum control on the rear but could this be the problem?
make sure you got all the bolts tight as for the vacc pull the vac hose off and when car is below 750 rpm there should be vacc there if not you could have a bad solenoid but i would dbl chk all the bolts first
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMef9 »</TD></TR><TR><TD CLASS="quote">I just replaced the front and rear mounts on a 1990 accord automatic. When the car is stopped and you shift from park to reverse or to drive the motor moves a lot. I dont know much about the vacuum control on the rear but could this be the problem? </TD></TR></TABLE>
Same thing for my auto 93. I replaced both front and rear mounts but it shakes when I shift from park to D4. Sometimes during shifting it also shakes. Really frustrated now!
h22accordian
Nov 2, 2011 04:32 PM
StupidSlowRSX
Aug 19, 2006 08:03 PM
