EG rear wheel bearings
i need a new wheel bearing on my 93 CX with drum brakes. before u all say, "just do a disc conversion", for me thats not an option right now.
i need to know if u can replace the bearing or if u have to get a whole new hub and everything.... and if i DO need a nwe hub and **** will 1 from a 88-91 civic work cause i have 1 for parts
thanks
thanks
i was told by the dealer that you have to replace the whole hub on the rears. i had a 95 ex w/ drums, hub was ~$100 new i think when i did mine.
Modified by sceg at 10:34 AM 6/19/2005
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sceg »</TD></TR><TR><TD CLASS="quote">i was told by the dealer that you have to replace the whole hub on the rears. </TD></TR></TABLE>
this is correct. it is very very simple. the hub/bearing is one unit. all you need to do is remove the drum, remove the 32 mm nut, swap hubs, reinstall in reverse order. extremely simple. can be done in 10~15 minutes max.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney »</TD></TR><TR><TD CLASS="quote">
thanks a lot i thoguht i had to buy the whole splinle with the arms and everything for rear drums. good to know
</TD></TR></TABLE>thanks a lot i thoguht i had to buy the whole splinle with the arms and everything for rear drums. good to know
MarkCayabyab
Oct 7, 2017 11:40 AM
shorti
10
Jan 14, 2003 12:22 PM
