LS/VTEC head leaking oil
Old Jun 19, 2005 | 02:30 AM
slowteg140's Avatar
Default LS/VTEC head leaking oil
I just did an ls vtec on my 92 ls and oil is leaking out of the head gasket right by the distributor. Just wondering if anybody else has had this problem or if they might know what is up.
Old Jun 19, 2005 | 05:46 AM
Racermech's Avatar
Default Re: LS/VTEC head leaking oil (slowteg140)
cam seal. vtec seal, valve cover seal, and i believe there is a seal for the distributor also.
Most likley is either the vtec or cam seal
Old Jun 19, 2005 | 05:50 AM
IN VTEC's Avatar
It might also be an issue with the plugged oil passage in the deck or the feed fitting that replaces the 3/8" BSPT plug in the intake-side of the head.
Clean the spill with brake parts cleaner and look for the leak by ruling out the highest possible leak points first while working your way down.
PatrickGSR94
Dec 19, 2014 08:02 AM
hatchyboy89
12
Sep 13, 2011 10:52 AM
hatchyboy89
Sep 10, 2011 09:07 PM
buttascotch_3
Apr 16, 2008 04:30 PM
Mr.DC2TurBo
Feb 16, 2005 12:57 PM
