ITR distributor same as GSR?
Old Jun 19, 2005 | 01:42 AM
S88HON's Avatar
Default Integra Type R Dizzy
Hi guys.. are these the same as '00 GSR dizzy's? i.e. cap etc???
Thanks...
Old Jun 19, 2005 | 07:08 AM
Opie's Avatar
I do not believe so, IIRC ITR dizzy's are compatible with B16 dizzy's.
Old Jun 19, 2005 | 10:54 AM
Stripped Honda's Avatar
99-0104
Default Re: (Opie)
i have a ITR dizzy on my 01 gsr and it works fine with no problems
Old Jun 19, 2005 | 11:42 AM
s2kdre's Avatar
Default Re: (Stripped Honda)
it should be the same bolt pattern on the head
Old Jun 19, 2005 | 11:50 AM
Chris F's Avatar
Default Re: (Opie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Opie &raquo;</TD></TR><TR><TD CLASS="quote">I do not believe so, IIRC ITR dizzy's are compatible with B16 dizzy's.</TD></TR></TABLE>
Careful... I believe this to be incorrect statement based on...
https://honda-tech.com/zerothread?id=1280308
Old Jun 19, 2005 | 11:56 AM
Jowee's Avatar
Default Re: (Chris F)
They're different. ITR rotor will fit in a GSR or B16, but a GSR/B16 rotor will not fit ITR. The GSR and ITR caps are the same part number though. Roger Foo had a ITR rotor in his Junk2 Civic to supposidly help it fire better at higher RPM. I've used the ITR rotor/cap in my GSR with no problems.
Old Jun 19, 2005 | 04:12 PM
ITR.#1446's Avatar
Default Re: (Jowee 1162)
not to jack your thread but i broke the gear on the diizy thats goes in the cam does anyone know where to get one?
Old Jun 19, 2005 | 09:20 PM
Opie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
Careful... I believe this to be incorrect statement based on...</TD></TR></TABLE>
Thanks for the correction, Chris
Old Jun 20, 2005 | 10:01 AM
SpeedyEk9's Avatar
Default Re: (Opie)
i have been running ITR cap and rotor in my gsr dizzy for the past 3 years
without a problem
92integraVTECgsr
Feb 16, 2006 08:47 PM
allmotorek8
Jul 13, 2005 03:19 PM
Jowee
Nov 11, 2003 04:06 PM
speedymon
Apr 9, 2003 03:07 PM
typeee
Apr 2, 2003 11:35 AM
