Is this B-engine bottom end setup possible?
B20/B18C crank>Stroke length=89mm/87.2mm,BE bore=48mm
F23 rods> CC length=141mm,PE bore=22mm,BE bore=48mm
K20A Pistons(milled down 0.6mm)>Diameter=86mm,PE bore=22mm
Rod/Stroke ratio=1.58/1.62
Engine Capacity=2068cc/2026cc
*PE=Pin-end
*BE=Bottom-end
Any advice, guys?
Modified by Edgar at 6:54 AM 6/19/2005
*PE=Pin-end
*BE=Bottom-end
Any advice, guys?
Stakis
18
Apr 24, 2018 06:34 PM
drewbie*
Jun 18, 2004 01:25 PM
B-20 bottom end for sale,wiesco piston/rings,eagle rods, ACL bearings,and everything else for the bo
Wilson C.
Oct 21, 2003 08:04 AM
