B+G LOCK RING JAMMED!!!!
I TRIED TO LOWER MY FRONT B+G COILOVERS AND AS I WAS LOWERING THE LOCKING RING, IT BECAME JAMMED. I THEN TRIED TO MOVE IT BACK UP, AND IT BECAME VERY TIGHT. THEN I TRIED MOVING IT BACK DOWN, AND IT BECAME EVEN TIGHTER. IT IS NOW JAMMED IN PLACE AND I NEED TO LOOSEN IT. I TRIED USING A HAMMER TO SEE IF IT WOULD UNJAMM, BUT THAT DIDNT WORK. IT ONLY MADE THE PROBLEM WORSE.
ANY IDEAS ON HOW I CAN GET IT UNJAMMED? I THINK THE THREADS MAY HAVE HAD A LITTLE BIT OF DIRT AND PEBBLES CAUSING THE LOCK RING TO JAMM.
spray some wd40, pb blaster or some carb cleaner on the threads and get the dirt out. alot of time dirt, pebbles and grime get caught up in the threads and make it screwed up
nexgen91
Jan 10, 2007 12:00 AM
null.
12
Aug 20, 2004 03:25 PM
