do the 16 inch rsx rims have any fit issues on the R rubbing etc?
i have a chance to buy a nice clean set and wondered it they would fit on the r without rubbing? thanks
Knowing Honda USDM, they are in the +50 to +45 offset range. If so, there shouldn't be any problem at all, even with the popular 215-45-16 size tyre.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">there shouldn't be any problem at all, even with the popular 215-45-16 size tyre.</TD></TR></TABLE>
I could not find so much choice for my JDM 16's.
Most are OEM's for NSX or others.
Just now Dunlop Direzza DZ101 has this size.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machgo5go »</TD></TR><TR><TD CLASS="quote">
Just now Dunlop Direzza DZ101 has this size.</TD></TR></TABLE>
If all you need is a high performance summer tyre, no chance of freezing weather, then the Hankook R2S Z212 might be a good choice. They're quite cheap for the handling they provide.
If you do need a tyre for cold weather, then the Falken Ziex 512 might be a good choice. I know they have 225-40-16 because I have them on my daily driver. At an indicated 60 miles per hour, you'd be travelling 57 miles per hour.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">If all you need is a high performance summer tyre, no chance of freezing weather, then the Hankook R2S Z212 might be a good choice. They're quite cheap for the handling they provide.
If you do need a tyre for cold weather, then the Falken Ziex 512 might be a good choice. I know they have 225-40-16 because I have them on my daily driver. At an indicated 60 miles per hour, you'd be travelling 57 miles per hour.</TD></TR></TABLE>
My R is only summer ride, no winter.
I just want to go back to OEM 16 size since I am currently using 215-40-16,
Kumho which not so fond of Korean tires.
I have rsx rims painted gunmetal on my black r and it looks pretty decent. My tires rub a little when I hit bumps....well hard bumps. I have 205 50 16 tires on it. It rides good but if you go with some 45's you'll be ok. I'll try to get some pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teepo »</TD></TR><TR><TD CLASS="quote"> My tires rub a little when I hit bumps....well hard bumps. I have 205 50 16 tires on it.</TD></TR></TABLE>
Stock springs? Hits right at the fender lip?
Stock springs? Hits right at the fender lip?</TD></TR></TABLE>
It's amazing how much of a difference there is between 205/50 and 205/45R16 on my car.
the 50's rub if you look at them wrong. Well, I do have a steep driveway, enough that I am on 3 wheels statically while pulling up into it. The worst part of it was right at the top of the wheel well in front, before I banged in the lip there.. This is lowered. Stock ride height I didn't rub, not noticeably.
-Chris
-Chris
The RSX 5 spoke wheel has almost no clearance with the caliper bracket. You'll have to use spacers on the front or put different calipers.
Rsx wheels clear my calipers and I'm on h and r race springs. it rubs in the back on the outer lip of the 1/4, and rubs slightly on full lock turn. I deal with it because it really isnt that bad. I cant even stick my pinky over the rear tire....thats how tight.
Aug 21, 2004 03:28 PM
