Accord solenoid going out can't shift out of Park
My solenoid is going out on my 99 automatic V6 Coup. I need to be able to drive the car to the dealer, but the shifter is stuck in park at my work. It seems worse in heat. In the morning I was able to hit the brake until it worked. Now I can't move it. I believe it's the solenoid because my brake lights are out too. A friend told me that some Honda's have a keyhole to disengage the shifter lock even when the car is off. Is this true? Where is it? Any help would be appriciated please!
Modified by Puppetkirk at 6:19 PM 6/18/2005
On my old accord auto there was one. You can take your key and there should be a lil indentation that you could use your key to push down to let u shift into the gears manually. Im not sure if the newer one has it but mine was where you shift theres a lil slit there and u just put your key in there. For your tail lights have you checked your brake switch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puppetkirk »</TD></TR><TR><TD CLASS="quote">I believe it's the solenoid because my brake lights are out too. </TD></TR></TABLE>
Sounds more like a bad brake switch or fuse to me. Does your horn work?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Puppetkirk »</TD></TR><TR><TD CLASS="quote"> A friend told me that some Honda's have a keyhole to disengage the shifter lock even when the car is off. Is this true? Where is it? </TD></TR></TABLE>
You have to remove the trim ring from around the base of the shifter to get to it.
jefff1964
Aug 5, 2017 06:15 AM
MJMAccord
Aug 22, 2010 03:23 PM
