best motor to swap in an ef
Old Jun 18, 2005 | 02:26 PM
drowzysleeper's Avatar
Default best motor to swap in an ef
just bought an ef hatch as was wondering what everyone suggested swapping into it ? i have never done a swap before so i was wondering what all i needed?
Old Jun 18, 2005 | 02:29 PM
Redline130's Avatar
Default Re: best motor to swap in an ef (drowzysleeper)
What are your goals? Daily driver, weekend warrior, or full race car? What kind of budget are you willing to spend on your car? Can you afford not having your car running for a few days or even a week or two? I suggest doing a lot of research before diving in.
Old Jun 18, 2005 | 02:41 PM
Default Re: best motor to swap in an ef (Redline130)
well i already have a daily driver, i just bought this ef shell for like 75.00 and was wanting to make it as fast as i can im really not on a budget because i would have to save up for anything i do so i guess whatever is the fastest. i would also like to know what all i would need for the complete swap into my car like i said never done as swap b4 i took my motor out when i rebuilt it and put it back in
Old Jun 18, 2005 | 06:32 PM
f@sth@tch89's Avatar
best motor for an EF...any b-series motor or some b-series hybrid i.e., LSVTEC or CRVTEC there is no cutting to put these motors in....
h-series... cutting is involved with this swap.
k-series...don't know if u cut or not, but i hate welding mounts...so until there is a bolt in mount kit i will stay b-series.
old tech article-----> http://hybrid2.honda-perf.org/tech/4gtech.html
Old Jun 19, 2005 | 12:47 PM
TrackSpeedRacing's Avatar
Default Re: best motor to swap in an ef (f@sth@tch89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f@sth@tch89 &raquo;</TD></TR><TR><TD CLASS="quote">[B]
old tech article-----&gt; http://hybrid2.honda-perf.org/tech/4gtech.html</TD></TR></TABLE>
until now....http://hasport.com/Products/Mount%20Kits/EFK1.htm
Modified by 1320JDMGSR at 2:50 PM 6/19/2005
Old Jun 19, 2005 | 02:53 PM
im wanting to put a b16a1 in the ef what all would i need to change to do that swap and would i have to have a custom turbo kit on it?
Old Jun 19, 2005 | 05:18 PM
i changed my mind about the b16 i have decided to go with a b18a my buddy is gonna sell me his for 300$ how hard would that swap be?
Old Jun 19, 2005 | 07:53 PM
bump
Old Jun 19, 2005 | 08:21 PM
Default Re: best motor to swap in an ef (1320JDMGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1320JDMGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by 1320JDMGSR at 2:50 PM 6/19/2005</TD></TR></TABLE>
i think u have to weld part of that mount kit. im personally going to stay away from those until someone creates a bolt in for the k-series. even thought my car is a track only car, i would still prefer a bolt in kit.
Old Jun 19, 2005 | 08:47 PM
importfan0103's Avatar
I've never done a swap into an ef but i have done a b18c in to a eg and ek, both are simple alls it takes is the right parts for the ef you will need shift linkage/axles/wiring harness converter(obd0 to 1or2 go boomslang for this great product and cheap) and mounts. I would put a cable tranny b16a in it.
Old Jun 20, 2005 | 01:25 AM
josholio's Avatar
Default Re: best motor to swap in an ef (importfan0103)
From what I've learnt, and been told, b series is easiest. I'm doin H22 at the mo. Heaps of cutting and welding. I work as a welder/fabricator so I'm doin all the work myself. Helps keep cost down. Would hate to think how much I'd be paying for someone else to do all this.
Old Jun 20, 2005 | 09:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importfan0103 &raquo;</TD></TR><TR><TD CLASS="quote">I've never done a swap into an ef but i have done a b18c in to a eg and ek, both are simple alls it takes is the right parts for the ef you will need shift linkage/axles/wiring harness converter(obd0 to 1or2 go boomslang for this great product and cheap) and mounts. I would put a cable tranny b16a in it.</TD></TR></TABLE>
do i need the ef stuff or the teg axles, wiring harness, and shift linkage
Old Jun 20, 2005 | 01:53 PM
Quad-Damag's Avatar
gsr all day yo
Old Jun 20, 2005 | 02:19 PM
APEX CRX's Avatar
Default Re: best motor to swap in an ef (Quad-Damage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quad-Damage &raquo;</TD></TR><TR><TD CLASS="quote">gsr all day yo </TD></TR></TABLE>
hell yeah
Old Jun 21, 2005 | 09:46 AM
Default Re: best motor to swap in an ef (APEX CRX)
im gonna go b18a because i can get it really cheap so does any one know where i i can get a turbo kit?
Old Jun 21, 2005 | 07:32 PM
SwissChEz82's Avatar
Default Re: best motor to swap in an ef (josholio)
HASport releases a kit next month for that swap.
Old Jun 22, 2005 | 11:40 AM
IHateJDM's Avatar
i think u have to weld part of that mount kit. im personally going to stay away from those until someone creates a bolt in for the k-series. even thought my car is a track only car, i would still prefer a bolt in kit.</TD></TR></TABLE>
the K as well as the H are physically too big to install without cutting/welding. There will never be a bolt in mount kit for either. Go B series .
Old Jun 22, 2005 | 06:31 PM
Mikey361's Avatar
Default Re: best motor to swap in an ef (IHateJDM)
i got a stock b16 in my ef , i love it , its reasonably quick , not super duper fast but its okay.
Old Jun 22, 2005 | 07:40 PM
Default Re: best motor to swap in an ef (mle_92cx)
where did you get your motor mounts and shift linkage?
Old Jun 22, 2005 | 08:12 PM
VTECVillain's Avatar
For the B18A you'll need an aftermarket mount kit and shift linkage: HASport or HCP are the top 2 brands, most others are just cheap knock-offs of those and tend not to fit as well or last as long.
Depending on the model EF you have, you might need to swap to DX/Si front hubs to fit the B series axles as well as convert to MPFI if it's not a Si model. If you're starting from scratch and don't have a cabin or engine harness, get the Si harnesses if possible to make things a little easier. There's tons of info on this swap here and elsewhere on the net. It's pretty straight forward given that you get the right parts.
alarikshelley
Jun 25, 2015 08:44 PM
TYPE WAHH
Apr 17, 2010 08:58 PM
Efcivicfukalex
Sep 12, 2007 02:23 PM
boosted97civic
Jan 10, 2007 12:39 PM
The ZC
Jun 19, 2004 10:33 AM
