new kid needing help
haha im new i got a couple questions about installing a cold air intake to my RSX S type i just ordered a injen cold air i heard you have to move the window washer fluid container over to the passenger side? is that correct ? any way if i have to does injen supply me with the proper nuts and bolts to do this ? if any one could give me some guidence it would be appreciated ! by the way in that purchase i also got some ceramic DC header and short shifter
You only relocate the washer bottle with the AEM. Injen provides you with a new smaller washer bottle that will accomodate the cold air tube and filter. All the nutts and bolts are included. Make sure you have the car in 5th gear so you clear your shift linkage.
With the header spray some pb blaster or wd40 on the bolts to take off the stock header because they are a bitch to get off. goodluck
The Injen CAI comes with a replacement bottle. I just did a 1476. Be prepared to drill new holes or enlarge the ones on the the bottle. They DO NOT line up right. That was a bitch. GL with the install, you'll love you intake. Sounds mean as ****.
EPM04
10
Apr 20, 2004 09:49 AM
Bklyn TSi
Jan 9, 2002 12:49 PM
SpoonFed
Nov 22, 2001 05:44 AM
