break or clutch?
Description: Brake fluid is a specially formulated liquid used in the brake hydraulic system. Brake fluid must meet one of three U.S. Department of Transportation (DOT) specifications. DOT3 and DOT4 are glycol-based fluids, which absorb water. DOT5 is a silicone-based fluid and does not absorb water. The main difference is that DOT3 and DOT4 absorb water, while DOT5 doesn't. Most cars use DOT 3 fluid from the factory.
Purpose: Since liquids can't be compressed, brake fluid transmits force to various parts of the braking system when you step on the brake pedal. Brake fluid must also have a high boiling point because of the heat generated during braking and must not freeze during cold temperatures. DOT 3 and DOT 4 fluids also attract small amounts of water that may collect in the brake system.
What I found with a quick search. I believe the higher the DOT rating, the higher the boiling point.
go to your local honda dealership parts store, tell them you need break fluid for your year car / model. they'll most likely hand you a bottle of DOT3 Brake fluid. Bingo.
if the brakes are low then i bet ur pads are getting worn check to see if they need replacing becuz if u keep adding fluid then wen u go to replace the pads u will have to compress the brake caliper to fit in the new pads and that will cause the fluid to overfill going everywhere so check that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote"> make sure that after you have opened a can of brake fluid, either use it or throw it away. Its not a keep it and top off affair like engine oil.</TD></TR></TABLE>
you can't use brake fluid after opening an old bottle? I did this for a while when my master clutch cyclinder was leaking... I kept a bottle of brake fluid with me in case the level go too low. Do you happen to know why this is or could explain it (i'm honestly curious)?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h8trix »</TD></TR><TR><TD CLASS="quote">
you can't use brake fluid after opening an old bottle? I did this for a while when my master clutch cyclinder was leaking... I kept a bottle of brake fluid with me in case the level go too low. Do you happen to know why this is or could explain it (i'm honestly curious)?</TD></TR></TABLE>
me2
me2
