owner of unorthodox utra ss pulley kit I need help!
I'm thinking about putting the ultra SS kit on my GSR 96... Is there something I should know about the installation? Are you guys satisfied about the pulley? Can you feel the gain? Somebody has bad issue with it
Btw I did a search but the last topic were 2-3 years old so I need fresh infos...
Thanks
Thanks
ive used their pulleys on my other cars and just bought a set of unorthodox pulleys for my 95 gsr.
theyre great quality products that install very easily and usually are an oem direct fit.
you really wont feel much of a gain by it self (you may feel some improvements by getting the full accessory set as well), it is lighter so your engine wont have to work as hard and will be able to put slightly more power to the wheels. how ever if you have a heavy audio system, your more likely to fry your alternator or drain your battery.
give this thread a look for some good info regarding the pulleys:
https://honda-tech.com/zerothread?id=1252468
