jdm b16a1 in a 90 teg
Old Jun 17, 2005 | 07:44 PM
t3gb0y420's Avatar
Default jdm b16a1 in a 90 teg
sorry if this has been posted but i couldn't find it. i need help wiring up my jdm b16a1 first gen motor to my teg. i know it bolts right in but i'm confuse about the wiring of the harness. i know everthing goes in place but oil pressure switch, knock sensor, vtec solenoid, 2nd o2 sensor, and a ground wire. I don't know how to wire those up. Another thing what ecu should i go with? I have the orgrinal ecu from the jdm b16a1, should i use that as my ecu? Any help would be great.
Old Jun 18, 2005 | 06:09 AM
90DA6teg's Avatar
what ecu, you will half to wire all of that seperatly. i ran my wires like that and didnt use the second o2 sensor. i havnt had a code go off with missing the second o2. just look where the pinouts go on the ecu then put them in. you will need the pins for the ecu itself.
Old Jun 18, 2005 | 09:04 AM
DAcraze's Avatar
Default Re: jdm b16a1 in a 90 teg (t3gb0y420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3gb0y420 &raquo;</TD></TR><TR><TD CLASS="quote">sorry if this has been posted but i couldn't find it. i need help wiring up my jdm b16a1 first gen motor to my teg. i know it bolts right in but i'm confuse about the wiring of the harness. i know everthing goes in place but oil pressure switch, knock sensor, vtec solenoid, 2nd o2 sensor, and a ground wire. I don't know how to wire those up. Another thing what ecu should i go with? I have the orgrinal ecu from the jdm b16a1, should i use that as my ecu? Any help would be great.</TD></TR></TABLE>
hey man ive done the exact same swap on my car and my biggest problem was the wiring also, yes u should go with the pr3 (b16a) ecu. im in class right now, im gunna find u some useful info, ill get back to u in a couple hours
Old Jun 18, 2005 | 09:08 AM
DAcraze's Avatar
Default Re: jdm b16a1 in a 90 teg (DAcraze)
http://www.geocities.com/teampimports/b16a.html
let me kno if that helps
Kimbo
Jan 21, 2011 07:51 AM
camp_kill_yourself
Jan 5, 2007 11:44 AM
integrawow
Nov 6, 2006 08:00 PM
Slowass4dr
Nov 11, 2005 06:29 PM
Nisif
Apr 11, 2005 12:47 AM
