H22a Swap... Which engine Harness? dc2
Old Jun 17, 2005 | 05:27 PM
lak8's Avatar
Default H22a Swap... Which engine Harness? dc2
Hello,
I own a 97 gsr integra shell. Im going to drop in a h22a engine swap but i need a engine wiring harness sence my dc2 didnt come with one.
Which engine wiring harness is the best to use for this swap and easyest to install (i dont have the stock one)
Dan
Old Jun 17, 2005 | 07:59 PM
v4lu3s's Avatar
RTFM
the stock one, if you dont have it go buy it from someone else or the junkyard.
Old Jun 18, 2005 | 10:26 AM
lak8's Avatar
Default Re: (v4lu3s)
anyone one else
Old Jun 18, 2005 | 07:17 PM
lak8's Avatar
Default Re: (lak8)
should i use a obd2a engine harness or just buy a obd1 harness sence the engine is obd1.
Would it make it easyer to buy a gsr wiring harness
Need some more input.
Old Jun 18, 2005 | 07:56 PM
v4lu3s's Avatar
RTFM
i would buy one that matches the shell of the car so it plugs into teh car, you can mod the rest of it to fit the engine.
Old Jun 18, 2005 | 08:12 PM
Turbogixxer's Avatar
Default Re: (lak8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lak8 &raquo;</TD></TR><TR><TD CLASS="quote">should i use a obd2a engine harness or just buy a obd1 harness sence the engine is obd1.
Would it make it easyer to buy a gsr wiring harness</TD></TR></TABLE>
IF you buy a OBD1 GSR, you will have less wiring to do if you would buy a OBD2 GSR harness. Both OBD1 and OBD2 engine harnesses will plug and work to your chassis harness (the connectors at both shock towers).
If you buy a OBD2 harness (has to be a integra harness, a OBD2 civic harness will not work). You will have to convert the injectors, distributor, evap purge, IAT, and other small things that will not have to on the OBD1 harness.
Note: IF you get a civic harness, depending on the trim, you may have to go some good amount of wiring work to do it.
OBD1 GSR is the easier and less harness you will need to rework.
Old Jun 18, 2005 | 08:16 PM
lak8's Avatar
Default Re: (Turbogixxer)
Thank you very much Turbogixxer
time to buy a gsr obd1 harness
more input if anyone else wants to say something
Old Jun 20, 2005 | 04:22 AM
lak8's Avatar
bump for anyone elses thought
Old Jun 20, 2005 | 10:52 AM
skunked's Avatar
Default Re: (lak8)
Listen to Turbogixxer, he is absolutely correct.
&lt;-----OBD1 GSR+OBD1 H22
Old Jun 20, 2005 | 06:48 PM
lak8's Avatar
Default Re: (skunked)
thanks im buying a obd1 gsr harness tommorow
Old Jun 21, 2005 | 07:02 AM
skunked's Avatar
Default Re: (lak8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lak8 &raquo;</TD></TR><TR><TD CLASS="quote">thanks im buying a obd1 gsr harness tommorow </TD></TR></TABLE>
No problem. Be prepared to lengthen the starter and alternator wires.
snowpro127
Northeast (Sales)
Jun 2, 2008 12:07 PM
92integraVTECgsr
Nov 1, 2007 05:56 PM
1BADEGDC2
May 12, 2007 07:43 PM
evilvtec22
Jan 23, 2004 09:31 AM
beseman
Aug 6, 2003 08:46 PM
