Need horn help, Installing momo wheel and hub, which is the horn wire?
As long as I dont have to take out any more Metal Gears
the momo hub we got is the type that must have the SRS removed in order to be installed. However I cannot find the wire that belongs to the horn. If someone knows, please help, thanks
this alarm installation has the horn wire I think you're looking for.
https://honda-tech.com/zerothread?id=605385
There is a yellow connector where this is found at the base of the steering column. Eveything wrapped in yellow is the SRS system - there is a connector which has one wire wrapped in yellow, two light green wires, and the blue/black horn wire. To test it - ground it and the horn will sound.
hey good info, thanks a lot and I will check it out
cmross13
10
Feb 27, 2010 11:39 AM
mahatma
10
Jul 11, 2005 08:18 AM
