gsr springs in 91 civic si
Old Feb 11, 2002 | 05:02 PM
Top_spec's Avatar
Default gsr springs in 91 civic si
yeah i was just wondering if the 96 gsr springs would fit in my civic and if the spring rate is higher than the normal si ones
Old Feb 11, 2002 | 05:36 PM
89civic1.8T's Avatar
Default Re: gsr springs in 91 civic si (Top_spec)
I tried this one time and it didn't work too well the car was jacked up to the max! IT was problably lifted 2-3" over stock! It was weird getting out of my car and steping down. I do not sugest you try this unless you get them a bit.
Old Feb 11, 2002 | 06:17 PM
Todd00's Avatar
I said I don't want a title!
Default Re: gsr springs in 91 civic si (89civic1.8T)
GSR springs on a 88-91 Civic will definitely be rally-car style. If you are just going to pitch the GSR springs, cut off a coil or two and then throw them in there.
Old Feb 11, 2002 | 06:22 PM
Top_spec's Avatar
thats what i was thinking if i was to cut a couple of coils would it be alittle lower and just as stiff as my stock springs and plus i am getting the springs for free would it be worth the trouble
Old Feb 11, 2002 | 06:35 PM
*Boostwerks*'s Avatar
DO NOT CUT SPRINGS!!! If you are the slightest milimeter off, it will result in wierd handeling, and an uneven drop.
just too risky to do. save your self some work, pain, and put down a measly 80 bucks for cheep lowering springs.
Old Feb 11, 2002 | 06:57 PM
Todd00's Avatar
If they are free, then cut them. Just be careful about cutting them all the same, and you'll be ok.
Having passengers in a car disrupts handling more than a few mm of on a spring cut.
Old Feb 11, 2002 | 07:07 PM
Top_spec's Avatar
Default Re: gsr springs in 91 civic si (Todd00)
yeah they are free my friend bought neuspeed lowering springs and i am gonna change them for him so i am gonna keep them and get them cut and put them in just to see if i dont like it i still have my old springs
so its not much of a loss
om_youssef
Honda Civic (2006 - 2015)
May 23, 2018 06:05 AM
weak_tec
Aug 25, 2005 08:51 PM
WhatItDo
12
Mar 26, 2004 12:31 PM
greatgraffini
Dec 2, 2003 10:28 PM
