EGR Removal
So what happens if you remove the EGR valve, and blank off the holes, then remove the corresponding EGR Control Solenoid Valve, EGR Vacuum Control Valve, vacuum hoses, and plug the holes on the IM??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yield »</TD></TR><TR><TD CLASS="quote">OBDI you'll get a code too - you can block it but you have to have it plugged in.</TD></TR></TABLE>
No you don't, read this thread:
https://honda-tech.com/zerothread?id=1277535
i did a write up on how to bypass that on OBD1 so you don't get a CEL.
