B18B cams and valve springs
A frined of mine is going to run a 12hour endurance race and need to get some cams for this engine. Any suggestions?
He will probably be changing the stroke to 87.2 and use most of the B18C-R components but we need new cams. Any suggestions would help.
Modified by CRVEF8 at 4:17 AM 6/19/2005
For race though you want the 404's!
So you will be using a LS block with GSR crank, rods, and ITR pistons?
Which pistons P73-A0 or P73-00? Personally I say go with the the P73-00. THey will yeild a higher compression and you will need that for the 404's
will be running the car for a 12hr endurance race. the internals will be a integra type R 96 spec. Thanks guys if you have any more info please post it thanks
