Trying to wire up my car...
i relocated the fuse box, and did a swap at the same time.. on im holding the fuse box right now. trying to figure this out.
There are 2 terminals, one that comes from the harness and the battery terminal. and there is one other.. i would assume its for ground, but i used my multimeter and the 2 are shorted together. I dont knwo if that is supposed to be like that..
but the 2 terminals go to a fuse, an 80amp fuse, does anyone have a pic.. of what im tlkaing about?? this is getting frusterating
Im not being a dick...
I've read your post twice now and I still cant follow it. Can you edit it and try to post your problem in a different way? Maybe that'll help us better understand what you need.
If both terminals go to a fuse then neither of them would be grounds....right ?
Sounds like you are talking about a high amp. fuse link.
Post a pic ?
Post a pic ?
