speedometer issue, need help/advice
Old Jun 17, 2005 | 06:09 AM
mr. goodwrench's Avatar
Default speedometer issue, need help/advice
okay, when drive my car, after like 3-5 minutes my speedometer dies. do anyone know why it's like that? when this happen, if i let the car sit for a while and restart the engine the speedometer will run again but after the 3-5 minutes it'll die again.
i'm thinking that there's a temp issue. but not sure. that's because everytime it dies, i notice that it's when the car warms up to running condition. also the only time the speedometer will start running again is when the engine is cool.
also my rpm gauge run fine. and i never have a issue with it, if that info. is any help.
any help or advice on fixing this issue will be greatly appreicated. i'm not trying to get a ticket for speeding.
Old Jun 17, 2005 | 06:38 AM
supaman111's Avatar
Default Re: speedometer issue, need help/advice (mr. goodwrench)
when you dizzy is on its way out your speedo goes crazy, could be this.
Old Jun 17, 2005 | 06:42 AM
allanonjj's Avatar
Default Re: speedometer issue, need help/advice (supaman111)
what the heck is a "dizzy"?
Old Jun 17, 2005 | 06:50 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supaman111 &raquo;</TD></TR><TR><TD CLASS="quote">when you dizzy is on its way out your speedo goes crazy, could be this.</TD></TR></TABLE>
not really, it'll run perfectly fine. just that it'll die once the car really gets going. right before the pointer drops dead, it'll go nuts for a split second at whatever speed i'm at and drops to zero.
dizzy is the distributor
Old Jun 17, 2005 | 07:22 AM
allanonjj's Avatar
oh....... duh, dont I feel dumb
Old Jun 17, 2005 | 07:58 AM
supaman111's Avatar
is it your engine that dies or just your speedo, as the dizzy going will not effect driveability as the bearings inside them go which then allows oil into the electrics which effects speedo.
sam
Old Jun 17, 2005 | 08:32 AM
the engine doesn't die, just the speedometer. but the rest of what your saying is confusing me. you're talking to a rookie in cars, so a little more explanation might help me out.
Old Jun 17, 2005 | 08:39 AM
supaman111's Avatar
what engine does your car have?
Old Jun 17, 2005 | 08:49 AM
B00M3R's Avatar
The Speed sensor is on the front of the trany close to the exaust. could be that when the car warms up its heating the wire or connection and causing a short.
just a guess.
I have a problem with my connection where it drops out just driving down the street. its just a wire problem but it mostly happens when its warmed up.
Old Jun 17, 2005 | 08:52 AM
EKrckstarr's Avatar
the issue could be your vehicle speed sensor i have a friend having the same problems the speedo bounces all around check the local junk yads for another one its fairly easy to replace 2 screws and it pops right out ...where to find it if you look staright down from the battery on top of the tranny you will see a component thats the culprit just change it and the speedo will be on the good foot.
Old Jun 17, 2005 | 01:33 PM
Default Re: speedometer issue, need help/advice (EKrckstarr)
i'm not sure where it at. my cars a 98 civic ex with its stock motor and the battery doesn't sit on top of the tranny like the others that may do. if anyone have a clear pix of the sensor on my engine it'll help alot. as stated before i'm a total rookie in the car scene. every ones help have been appreciate so far. thanks!
Old Jun 17, 2005 | 02:46 PM
okay never mind. i'm so stupid. i found where it's at. thank to everyone who replied. i'll probably replace it and see what happens.
Cmorcivic
Engine Management and Tuning
May 15, 2013 07:42 PM
jbmcnamara
Nov 22, 2010 03:46 PM
ITR_HO
Jul 23, 2007 12:04 PM
