bored out gsr throttle body
so i had an extra throttle body and had it bored it by this guy that my friend knows.. i out it on and it idles at 2500/3000rpm...i took it off and put my stock one bak on and everything was fine....i dunt think thinks the gasket cuz its the same one i use for both of dem...but there WAS a hosing that goes to a nipple on my STOCK t/b next to the top sensor.....but the bored out tb dunt have a nipple, check the hole it had,doesnt suck or blow....then i check the hose and follow it to a BLACK cylinder under the brake filter...(pvc >? i forget) but it doesnt suck OR blow from the hosing...i dont know if thats the problem ..i always heard i might need to get it recalibrated...is it true? or is it the idle screw?? i try to screw it but didnt move..seem like i was bouta strip it soo i just stop. not i got my stock tb back....
any ideal?
any ideal?
Wow...spacing and actual words really help people understand what youre trying to say.
The reason it idled so high is because you had a loose hose - a vacuum leak.
I cant figure out what hose it is youre talking about, but it either needs to be plugged or spliced in with another hose, if the new throttle body doesnt have a spot for it. (Chances are, you will need to splice into another, rather than plug)
