need advice
I'm looking to buy a used Type-R and i found one. The guy left this as what he has done to the engine.
Motor has a worked head(ported and polished) with cams, springs and retainers, raised compression ratio, light weight flywheel, brand new clutch, ETC. Suspension is H&R fully adjustible coilovers so car can be raised or lowered 4" and still retain a smooth ride.
Is this a good thing? Will i have problems? Can i get all these things back so the engine is like stock? Basically, whats going on?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech euro »</TD></TR><TR><TD CLASS="quote">Basically, whats going on?</TD></TR></TABLE>
Ha!
Stock type R heads aren't terribly cheap, and you can't un-port a head. You may find someone that wants to trade with you.
You can find stock cams, valvesprings, etc.
Depending on how he raised the compression ratio (Pistons?) that would be another expense to undo.
Flywheel and clutch are easy to undo, again not cheap, labor is expensive if you don't do it yourself.
Suspension is easy to undo, you just have to find the stock parts again, you should be able to do that yourself.
Do you REALLY want to bring it back to stock?
Good luck.
Ha!
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech euro »</TD></TR><TR><TD CLASS="quote">Motor has a worked head(ported and polished) with cams, springs and retainers, raised compression ratio, light weight flywheel, brand new clutch, ETC. Suspension is H&R fully adjustible coilovers so car can be raised or lowered 4" and still retain a smooth ride.</TD></TR></TABLE>
Please see if you can find out more about who did the work on the head, what springs and retainers were used, what cams he used, and how it was tuned, by whom and when.
I'm guessing the compression was raised with a slight milling of the head, since he was doing head work anyway. You want to know who did the head work, because that makes all the difference in the world.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtech euro »</TD></TR><TR><TD CLASS="quote">was the engine changed for the better?</TD></TR></TABLE>
If the guy put $$ into it, let's hope so.
BTW, vtech = a telephone.
You tell us. It could be a lot stronger of a motor, it could be a time bomb.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">Please see if you can find out more about who did the work on the head, what springs and retainers were used, what cams he used, and how it was tuned, by whom and when.
I'm guessing the compression was raised with a slight milling of the head, since he was doing head work anyway. You want to know who did the head work, because that makes all the difference in the world.</TD></TR></TABLE>
^^ i'm gonna go with the time bomb theory.. I purchased my ITR 2 years ago with alot of work on the stock b18c5.. one month after purchasing the car on the freeway i shot a rod through the block. now i'm a proud owner of a Jdm motor yo!. lol.. Pick it up just have some cash saved up for when she does blow
rewerbcrx
Dec 30, 2006 09:06 AM
sikciv666
May 22, 2004 07:06 AM
