Suspension & Brakes Theory, alignment, spring rates....
question about capadible suspensions
Old Jun 16, 2005 | 08:56 PM
thino's Avatar
Default question about capadible suspensions
aftermarket full coilover systems such as tanabe, zeal, tein, JIC, ect. is the DC2 type-r
capadible with the eg/eh suspension ?
Old Jun 16, 2005 | 10:45 PM
PIC Performance's Avatar
Default Re: question about capadible suspensions (thino)
The type-r uses a box-style lower mount in the rear, which is different from all the other EG/DC2's, so the companies usually make a model with that style lower mount specifically. If you have a set designed for the ITR but have an EG chassis, then you'd have to switch out your lca's for the ITR's lca's, or switch out the lower mounts for regular EG fork-style lower mounts to match your existing lca's.
And its spelled "compatible".
Old Jun 17, 2005 | 01:25 PM
thino's Avatar
Default Re: question about capadible suspensions (Noob4life)
i thought so. thanks dude
BOOSTWERKS
Mid-Atlantic (Sales)
Nov 20, 2008 10:49 AM
BOOSTWERKS
Oct 27, 2008 08:43 AM
ReactioN
May 21, 2008 09:05 AM
604Squad
Apr 15, 2007 10:09 PM
