So i decided to take apart the V-AFC.....
Old Feb 11, 2002 | 02:50 PM
Renegade's Avatar
Default So i decided to take apart the V-AFC.....
Here are the pics..
I did it to look for a way to add a switch so I can switch the display on and off.
[Modified by 98401R, 11:51 PM 2/11/2002]
[Modified by 98401R, 11:52 PM 2/11/2002]
[Modified by 98401R, 11:53 PM 2/11/2002]
Old Feb 11, 2002 | 02:55 PM
ThePunk's Avatar
Default Re: So i decided to take apart the V-AFC..... (98401R)
Well,
Did you find a place for the switch?
Old Feb 11, 2002 | 02:59 PM
Renegade's Avatar
Default Re: So i decided to take apart the V-AFC..... (ThePunk)
nah, the display is built by Futaba Corp. Apex just gets the displays from them and connects their board to it, I dont' think they even know how, I will need to call Futaba and ask them. By looking at the board it looks as I will need to tap into the board, I was thinking along the lines of tapping into a wire. I'll post what I find out. Whenever I do
Old Feb 11, 2002 | 03:00 PM
B2FiNiTY's Avatar
Good luck
Old Feb 11, 2002 | 03:09 PM
yoshi234's Avatar
I shoot brides
send it to me, i'll put a switch in it
Old Feb 11, 2002 | 03:12 PM
Renegade's Avatar
Default Re: So i decided to take apart the V-AFC..... (yoshi234)
you know something I don't, like where the display power lead is?
Old Feb 11, 2002 | 03:17 PM
Hukd Up's Avatar
why would u want to switch the display on and off?
it looks bomb on!
Old Feb 11, 2002 | 03:36 PM
Renegade's Avatar
Default Re: So i decided to take apart the V-AFC..... (out_a_bounz)
I want to embed it under the tachometer, but would not like it to be really obvoius.
Old Feb 11, 2002 | 04:16 PM
Floyd's Avatar
Can the display be removed from the PC board?
Old Feb 11, 2002 | 04:21 PM
Renegade's Avatar
Default Re: So i decided to take apart the V-AFC..... (Floyd)
No the actual display is soldered onto the board.
Old Feb 11, 2002 | 04:48 PM
Rob :190:'s Avatar
that would be cool to have like a smaller remote display and put the 'guts' of it somewhere else, would make mounting a bit cooler.
Old Feb 11, 2002 | 06:12 PM
Spyderwebab's Avatar
Default Re: So i decided to take apart the V-AFC..... (Rob1035)
If you haven't already seen this installation, you have to check it out. Mounted in Driver's side Sun Visor. Totally concealed, Looks great! AWESOME IDEA! I'm thinking about doing it. <A HREF="https://honda-tech.com/zerothread?&id=127459
" TARGET="_blank">https://honda-tech.com/zerothread?id=127459
</a>
Old Feb 11, 2002 | 06:18 PM
Renegade's Avatar
Default Re: So i decided to take apart the V-AFC..... (Spyderwebab)
that looks tight.
Old Feb 11, 2002 | 06:47 PM
Floyd's Avatar
Bummer. That would open up a bunch of possibilities...
Old Feb 11, 2002 | 06:50 PM
Renegade's Avatar
if you wanted to risk it, you could disconnect the display and solder wires to it and do the same to the other end, that way you could put the display anywhere. Very tedious.
maischi
Dec 1, 2002 05:28 PM
EGO
Nov 22, 2002 11:09 AM
Importteg95
Nov 14, 2002 05:58 AM
cxb18c1
19
Nov 4, 2002 10:53 AM
eg_nezay
89
Sep 20, 2002 08:58 PM
